Do you guys ever listen to music, or just talk about it?
I hate to interrupt the conversation here but....
Tom
Tom, I appreciate your continued interest in my system thread.
Tom
As I understand it, it was simply about amp speaker pairing, independent of room context. The recommendation was not about what would work. It was about what would sound best.
Good question,i fully agree that treatments, whatever they may be, can reduce micro-dynamics in their effects. makes sense it can happen.
so i understand your point about micro-dynamics. but are you saying 'black backgrounds' = is the same things as......reduced micro-dynamics?
or are 'black backgrounds' a different thing? it seems to me that 'black backgrounds' have more to do with recordings, than gear. the absence of ambience, or a recording mixed where voices or instruments are isolated from the venue. something different than optimal realism in the event. for example some electronic music is obviously, intentionally made with black backgrounds, and still be enjoyable for what it is, realizing what it's not. and we don't use that as a reference for realism either.
if you can think of a treatment or tweak that causes 'black backgrounds'? not reduction in micro-dynamics, that was my question to you.
i do think that if a tweak raises the noise floor, or adds a veiling, then it would cover 'some' ambient information. but most tweaks are intended to cause the opposite effect. however, this 'effect' would be a different thing than a 'black background' although it might be related to it.
and i don't want to beat this dead horse, i'm fine with no answer and we can move on. thanks.
Thank you.
It's puzzling to me, because the corner-required implementation makes it a very specialized speaker -- which you are saying Vladimir advised as a general optimal answer about what would sound best with his 18 watt SET amplifiers.
Years later, this is the only known pair to still exist, and it is in original and excellent condition. This pair represents a moment in time, and is unique. Never was this pairing meant to be a general recommendation to the public.
If I understand this correctly, the corner horn speaker extends bass in a smaller package by using the walls as the final extensions to the bass horn, yes?Very specialized speaker? Rooms have corners. This was the late 50s and the recommendation was made later after the ML2. The early Vitavox ads asked “Do you have two square feet of space in your room?” They were sold as mono speakers. Vladimir and David demonstrated newer versions and the Bionors at a show. I don’t know what to tell you.
BTW, I did not say Vladimir's recommendation was a general optimal answer. It was a very specific answer to a question. If you continue to remain puzzled, just call David and he might explain it to you.
I am sorry , but what on Earth are you talking about here ?
Vitavox CN - 191 are *Not* quite as rare as you like to make out , certainly not in the UK and laterally amongst vintage collectors in the Far East , your version of events rather smack's of a Fable that you have been sold on .
My first Vintage CN-191 mono was marked BL . 7 . 1A on the top of the main bass horn , the second was a partial re build of the rear cabinet due to woodworm , ergo not an essential section of the back horn , but the factory designation was missing , the Third mono which matched pretty darn closely with regard to the veneer's of No1 was marked BL . 7 . 2A , All three were also signed off *Inspector D . Johnstone* … my friend who let me buy the second to match CN-191’s from also had a pair marked BL . 6 . 1A and BL . 6 . 1A , this was back in the early 80’s and CN 191’s came up in sales and auctions a few times a year.
There are quite a few to be seen over in the Far East amongst the Vintage collectors , which Is where my final two were sold and shipped to Hong Kong .
A very nice pair for example :
If you think those are the same speakers as the ones I have, I don’t know what to tell you. They are clearly different. All you have to do is look at the cabinet shape.
Show us an image of a pair of these speakers from the late 50s that match the shape of my cabinets. And included a photograph of the crossovers
You know how to Google … Don’t you ? My first and third were identical to your build , the second was slightly different in the wooden enclosure of the compression horn and very similar to the ones in the above YouTube.
www.monoandstereo.com
yes, these things are different......but the consequence to the music ends up being similar. i can agree on that.Good question,
I do not say black background is 100% equal to blocking micro dynamics.
I think the effects of some electronic records is different to effects of ac filters. Some records may have more background silence and less ambient or even less decay but this effect is not quite similar to adding AC filters.
I can hear micro dynamics from good records but I never hear micro dynamics from AC filters.
yes, that is what i prefer too.I think the real challenge is lowering noise without killing micro dynamics. Using high amount of negative feedback lower the noise but kill dynamics. Adding extra shield and parallel capacitor lower the noise but kill dynamics.
Designing a wide dynamic range (low distortion high SNR) zero/low feedback amplifier is the art .
For AC quality I believe in high power AC regenerator.
i appreciate you taking the trouble to explain and get more specific in your meanings, thank you. and agree with much of your perspective.With right solutions for Lowering the noise without killing dynamics :
- more image depth
- more purity less forwardness more velvet texture
- more dynamic range/bigger scale
- better micro dynamics
- more background silence
Some examples of black background:
Mark levinson no.383 integrated amplifier
Cardas golden reference cable (2008)
Furutech cables
Most AC filters (except Ayre L5XE)
CAD ground GC3
Most audiophile AC cables
With bad solutions for Lowering the noise:
- blacker background
- more colorful tone
- less dynamic / more dead sound
- less contrast
- feeling of more clean hifi sound
Even the resurrected Vitavox UK company have chosen to replicate the exact same style of cabinet ( as yours ) for their very high quality reproduction CN - 191 :
Vitavox Hifi - Vitavox continues to build on this illustrious history hand crafting components to power some of the world's finest loudspeaker systems
For over three quarters of a century the name Vitavox has stood for the finest quality in sound reproduction; a reputation built on a dedication to excellence in design and engineering that has remained undiminished. Today, Vitavox continues to build on this illustrious history; hand crafting...www.vitavoxhifi.co.uk
Vitavox CN191 speakers – M & S | Ultimate High-Fidelity
Even Vitavox’s own original advertising material featured an accurate representation of the exact same revision of cabinet as your two !
You own a very nice condition couple of vintage horn transducers … Be happy in that !
One has to be very careful about lumping things together! Class A covers SETs, PP, SE transistor amps and PP transistor amps so you can see a pretty wild variation in the sound with them... class D is the same way in that some are outright terrible and others are quite musical ceding nothing to class A amplifiers of good quality, even SETs.My only personal experience with Class D (apart from subwoofers) is MBL Noble (Class D) versus MBL (Class A) on MBL 101E Mk. IIs. I preferred the Noble as I think I found it a little bit warmer and a touch "smoother."
Yes, obviously! If you look back through my posts I mentioned some very specific titles.Do you guys ever listen to music, or just talk about it?
Yes.If I understand this correctly, the corner horn speaker extends bass in a smaller package by using the walls as the final extensions to the bass horn, yes?
The Hartsfield that Classic Audio Loudspeakers initially reproduced and has since improved also has good response into the low 30s or better. The first time I heard the Hartsfield was a good 30 years ago; since then John Wolff (of CAL) has done a lot with the drivers to improve the bottom end. It too features a folded bass horn and is designed for corners. But most of the time I've heard them, they were not in corners yet did the bottom end quite well nonstheless.These do look extremely similar, but they are not the same on the sides. The wood is also different as are the glues. I suspect, if directly compared to each other, they will sound different. Some will likely prefer the newer version and some the older one.
Yes, I used those measurements to make sure they would fit through the door into my listening room.
I find this quote from the MonoStereo article below somewhat interesting. I do not know the roll off, but I was thinking I get down to the mid 30's in my room. The room walls extending the horn mouth is what the corner horn is all about, and why I do not feel the need for subs in this room. I have no space to integrate them anyway.
"The bass cabinet is an ingeniously conceived folded horn, designed to be sited in the corner of a room where the walls and floor serve to greatly extend the effective size of the horn mouth, and thus bass performance. Loaded with our 15″ bass driver, designed specifically for acoustic duties such as these, it has no difficulties in reproducing frequencies as low as 30Hz."
Thank you. I am happy with the speakers. They remain the only original late 1950s pair of which I am aware. I would like to hear this new production version for comparison and check out the construction. I am glad someone thought the design is worth trying to revive.
