Do you mean like that HardieBacker construction materials product?Actually, I am considering replacing the sheet rock around the fireplace with concrete board and perhaps wood panels over that.
I understood your approach and cannot argue with your points. IMHO the biggest difference between houses in USA and Europe is drywall. In Europe or other parts of the world houses or apartments are build from bricks or concrete which is extremely stiff compared to drywall. Unlike concrete or brick, walls made of 2X4 wood lumbers that covered with drywalls on both sides are extremely reverberant. It requires a lot of treatment in a never ending story. I wonder why people try to add a subwoofer to their already full range speakers that can go down to 25Hz, trying to bring it down more to 20Hz? And why doing it in a drywalled room?
IMHO the biggest upgrade an audiophile in USA can do is moving to an all concrete/ brick walled listening room. Drywall is the worst thing I ever encountered, worse than glass to my ears.
I have never understood "pace, rhythm and timing" either.
Why is this?Obsession with frequency extension, imaging and detail is at odds with reproducing it.
You are not alone.
I think most audiophiles don't know what it is and very few systems are able to portray it properly. It is something you have to be highly aware of and go after.
Why is this?
Thanks for posting this!
I was going to post something similar as I have lived with both types of room and it is the biggest factor effecting performance.
I think it helps to explain why American audiophiles don't get PRAT and are obsessed with bass.
i think throwing stones at system aspirations as somehow exclusionary and negative is just wrong. it seems like it's more an excuse to ignore musical information that is on the recording. and rationalize system limitations.You are not alone.
Thank you.Because it is Really difficult to have both. You either go after one or the other.
The systems that I have heard that do PRAT have always been relatively simple - not massive and ambitious. The speakers have been single driver (full range) or two way with limited bass extension (maybe 35 to 50hz). I have heard the occasional 3 way system that did it, but it was a lot more work.
If you are after PRAT, imaging and detail are distractions. They are things that follow (the tail rather than the dog)
Frequency extension is very difficult to achieve because it adds complexity. At a minimum you need a 3 way, but probably 4+.
I believe it is concrete board.I don’t know what that is.
so you are saying the listeners here are more sophisticated. I will take that
If that were true I think Kedars would be more common here.If one were to generalize, I would say American audiophiles are obsessed with big, loud, expensive objects.
like you are proud and happily elitist for limiting particular things. i want to hear all types of music at it's best. and hear all aspects of the music that is possible to hear.
it's more challenging to attain it all for sure and not lose important parts. and trade-offs do occur on the road to system optimization.
just my 2 cents.
It’s quite possible you got exposed to PRAT over 16 years. You are going to get some new exposure in 16 years, irrespective of where you live. It might have happened elsewhere too. For example, I got exposed to analog living in London. Can’t conclude the city caused it. It was just time for the next stepI lived in England for 16 years and became exposed to PRAT.
Hmmmm , Now who might that remind me of ?And some times sell them a pair of speakers !![]()
Thanks.
Ron shared that both videos were made with the same tape (his tape of Soular Energy).
Same tape, same performance; no?
Thank you.
Do you think the best, or perhaps the only, way to achieve PRaT is with high sensitivity speakers and SET amplifiers?
thanks, sorry if i overreacted and appreciate you not doing that.Don't get me wrong, I am not throwing stones or criticizing other peoples aspirations!
generalizations with a negative bend can seem to be more pointed than intended. no doubt some systems succeed at peripheral things, but miss the musical connection and not be engaging by degrees. it can happen. but one needs to hear it to know.I am just explaining an observation. I have no problem with people enjoying whatever they like in whatever way they like.
I will not tell people what they should like or what they should listen to - hence my reluctance to participate in format war threads.
i don't subscribe to locations being evidence of any particular result with a particular system; but it's fair to recognize the plus's and minus's of styles of living.I lived in England for 16 years and became exposed to PRAT.
Living in Australia with housing construction similar to America I have found VERY difficult to get any of this. I have also found that my rooms chosen for audio reproduction are so leaky in the bass that it one is almost forced to add subwoofers.
