But the variability of microphone and recorder would make any comparison null and void.
Look Carlos has the best system on WBF ..... next ....
It only a “relative” comparison and not an apples-to-apples comparison. All variables can never be equal.But the variability of microphone and recorder would make any comparison null and void.
Look Carlos has the best system on WBF ..... next ....![]()
One’s system can improve through the process of comparative analysis.
I applaud your efforts, however, claims are presumed unfounded until sound evidence is provided, reviewed and agreed by credible sources. And to be frank, we often hear what we want to hear; it is a skill being completely objective, and some might say, inhuman.Lots of different discussion ideas.
Yes, 0.001 degree is audible. Actually less than 0.001 degree is audible. In my main system I can adjust the thread on the rear spikes of the spacehorns 4 or 5 times before the digital level (NIST Certified) moves from 0.454 to 0.455 and each of those spike turns is audible. The farther up the hill one pushes the performance the smaller and smaller change in position is noticable. However, most systems are in the wrong starting poinnt to hear this level of change. They speakers are so misaligned that 0.001 or 0.01 may not be so obvious. The sound is too far in the weeds. We start out moving the speaker on th order of inches then 1/4 inch then 1/16 inch and quickly it moves to bumps less than a mm. Just like on the spikes. The spike adjsutments start in the 1/4 to 1/2 turn range but quckly get down to barely turning the spikes (0.001 degree type thing.)
I have tried correlating REW measurements with speaker position. There are only broad things that can be said and usually that is only in the beginning of the setup process. If someone is looking for what in the measurement changed when the rake is adjusted 0.001 degrees then I don't think they are going to find it. At least I could not find it. All I can say is the most are greatly underestimating the ability of human hearing to detect very small changes and also to assess bad, good and better. When listening to music we know what instruments are supposted to sound like. We can also tell if they are playing together like professional musicians or if they sound like a hung over college band.
I have setup a range of speakers from pretty budget level to very high level. I have not run into one that I could not get organized sound out of. However, there are noise limitations. If a system is noisy then it limits how fine I can hear. And that limits how precisely I can determine the exact speaker position as it is not clearly defined.
It is unfortunate that most dealers are not so great at setup. As Roy said in the article, paraphrase -- the speakers were more installed than setup. I am amazed that it seems many (most?) dealers aren't even able to get a stable central image for vocals. I routinely find the image pulled to one side or the other. But this is why audio really can't be a luxury industry. Stuff doesn't work out of the box. You simply can't buy a bunch of gear, plug it in, and expect a satisfying musical experience. Someone has to have the skill to make it all work. That could be the owner, the dealer or some hired professional.
I view this as information for those who are trying to understand what is needed to get great sound out of a system. I have no reason to make any of this up. Roy reported on it and has written about his setup detail in many of his articles. One person on this forum that I setup his speakers reported on the process and the results. The person with the Ultime 2's is reporting on the results. Elliot and Steve have expressed that they have seen and heard this. All of this is independent observation. It is up to you what you want to do with the information.
I’m curious, what is the average cost of Stirling services is?I get it and I can understand your feelings. I have worked with Stirling, I have worked with Brandon Lauer ( a great set up person) and I have done many myself. When the system is really close to being right very small increments are audible, not sure thow one would measure them if at all possible but they are audible. I would happily invite you to our set day up at CAPFEST and you can sit and listen for yourself. It might open your eyes and your ears. It won't cost you a penny either LOL
Does you listening chair also need to adjust such that the listening position has the same distance to left and right speaker?Yes. The left speakers moved 12 inch closer to the side wall whereas the adjustments for the right speakers were marginal in terms of placement.
sbnx .. It is amazing that such small increments lead to these improvements.. do have any speculations on the physics involvedLots of different discussion ideas.
I admire anyone who spends the time to dial in their speakers, sweet spot and room acoustics for their optimal listening experience, but I question statements like, "In terms of attitude, both speakers are now raked back (rather than forwards) and sit within 1.2 hundredths of a degree fore and aft, four thousandths of a degree laterally." Sorry, but I would love to see the results of a per - hundredth / thousandth degree A/B test, as I find it inconceivable that adhering to.012 degrees and .004 degrees are humanly audible. The motion of sitting in the sweet spot seat and causing potential (and likely) position movement is likely more than that.
One more word about videos from you and you will not like the outcome. It will be permanent. We know your game and you have been warned multiple times.One’s system can improve through the process of comparative analysis.
I get the skepticism. I do. The more refined a system is, the basics covered, and the more you dial it in? The more it becomes apparent (the changes).My dog was playing with his toy and bumped into a speaker. Its way better sounding now. I charge $1000 to have my dog chase his stuffed squirrel in your living room.
(2) physical movement of the loudspeaker cables - due to accidentally moving the cable through unwitting contact from large physical object like a human leg, for example, the said human the leg belong to had been moving physically around the loudspeaker as the human being contemplating shifting loudspeaker positioning and toe-in angle.
due to the movement, certain portion of the loudspeaker cable may suddenly come into stress from being compressed.
the anxiety imposed onto the loudspeaker cable can create changes in sound timbre.
Now we're talking anxiety imposed onto a cable...
And a thousandth of a degree that can be heard.
None of this without a shred of proof other than, "I said so."
Noone will even entertain trying to prove they're correct by even attempting A B X. And plenty who agree. Convenient ignorance?
I'm not a diehard science - only guy, but it just might be time for me to head to another group. or at least be a lot more discerning of posts..
Makes sense, however, aren't customers listening to a less than ideal setup in the dealer's room(s) if they (dealer) don't know how to optimize a setup? Or do they hire someone else to do that for their rooms? Just curious.This is not a surprise and all dealers are not the same. This is the world we live in . IMO the more products a dealer cariies the less likely they are to be an expert on any of them. Its just math. Aren't most clients looking to get the best price rather than the best results? Be honest!
The level of expertise that people have is not the same thing as the their efforts and business skills to run a retail business.
If we want to have a serious dicussion on this topic let's be real and fair.
The store you buy your piano from probably is not the same guy that tunes it. The place you buy your cooking gear is not a teacher of gourmet cooking.
These are different skill sets and IMO the ability to properly position a speaker, or to optimize a turntable etc. are very different than running a store. They are not mutually exclusive but in most cases they probably are.
This is not a critic but let's look at Wilson almost every large install you see or hear about one of the factory staff is there to set the speakers up. This is not an accident its because it takes expertise and experience that most don't have. There is a reason that people like Stirling are booked up months in advance. Its not a controversy its just reality and people don't want to understand that the skills are not universal or gotten by opening a business.
