I have not seen any comparasions with players like Taiko, Pink Faun etc. Anyone had chance to hear these brands?
nice to see you made a choice PatrickI listened to most of the top streamers. In the end, I felt that the Pachanko was right there. It had just a touch of warmth to it that ultimately made me decide on it.
is Diretta an interface?I have to echo @Bogan88. Even as I listen to different units I have yet had the urge to switch to something else.
I have the Constellation Masterpiece with Diretta Target and Stellar LPS.
thanks. Saw that, but I'm a little thick. Is it software, hardware or both? Just curious.![]()
Diretta's solution involves close coordination between a Host and a Target, using predictive data transmission at consistent intervals to stabilize power consumption and enhance audio player performance. This process is akin to USB synchronization but with the Host controlling the pace, eliminating the need for complex buffer and flow control systems. This allows for isolated connections like fiber optics and simplifies processes compared to protocols like UPnP and AES67.is Diretta an interface?
Thank you. Does the Diretta (hardware + software) do any oversampling or is that done only within the DAC?Diretta's solution involves close coordination between a Host and a Target, using predictive data transmission at consistent intervals to stabilize power consumption and enhance audio player performance. This process is akin to USB synchronization but with the Host controlling the pace, eliminating the need for complex buffer and flow control systems. This allows for isolated connections like fiber optics and simplifies processes compared to protocols like UPnP and AES67.
Diretta's primary focus is on optimizing sound quality while minimizing impact on analog components. This is achieved through processing averaging and power consumption stabilization - something existing protocols struggle to accomplish - and now through Diretta, there is a solution to this challenge.
Imagine an audio player as the Target ( e.g Soulnote Z-3, SPEC RM-UB1, Oliospec Canarino) - a device dedicated to delivering pristine sound quality - and a server as the Host ( e.g Pachanko Labs with Roon, Audirvana) - responsible for managing storage and data delivery - These two entities are conceived with contrasting philosophies, both designed with distinct principles.
In the case of the Target, the design ethos is one of elegant simplicity. Unnecessary complexity is stripped away, opting for a streamlined approach akin to specialized hardware processing, reminiscent of the efficiency found in Field-Programmable Gate Arrays (FPGAs). This deliberate simplification allows for seamless harmonization between the player and its supporting infrastructure.
By carefully calibrating the Host and Target to work in tandem, Diretta endeavors to strike a harmonious balance between high-performance audio reproduction and the minimization of digital intrusions.
Oversampling is made through the player or DACThank you. Does the Diretta (hardware + software) do any oversampling or is that done only within the DAC?
Top 11 Best Sounding room in High End Munich 23 using Pachanko's entry level model (Mini SE) says it all. As a loudspeaker manufacturer, we have a free will to use any brands to show the best of our products. Very pleased with the performance and reliability of Pachanko server and will be using Pachanko's higher end model in High End Munich 2024. Action speaks louder than words.I have not seen any comparasions with players like Taiko, Pink Faun etc. Anyone had chance to hear these brands?
I will be there.will be using Pachanko's higher end model in High End Munich 2024
Clearly this is a question for Sonner. But I have Roon, Roon w/HQPlayer, and Audirvana on my Masterpiece. It is pretty simple to switch back and forth between them.I will be there.
Do you intend to demo with Roon or Audirvana?
Thx
We don't know yetI will be there.
Thx
I have seen there is also a Pachanko room with OM-Speakers at H3, P11We don't know yet
YesI have seen there is also a Pachanko room with OM-Speakers at H3, P11
