Sure most music recorded in the past 30 years are in digital format. But early Redbook digital sucks. That already rules out a large part of the catalogue. I don't think any manipulation today can salvage the problems caused by the awful sounding early digital tape machines, convertors, DAWs etc. And try getting Pink Floyd, Led Zeppelin (bring Bonzo back to life !), the Beatles, Heifetz, Du Pre etc. to make a digital recording...... Not that there aren't great performers in the digital era, but these folks were unique. I agree original digital recordings are better off staying digital. But are old analogue recordings better converted to digital or cut into vinyl LPs ? For me, I try to get as close to the original as possible by getting hold of the master tapes. A 15 ips 1:1 copy of the master (production or safety) usually sounds better to me than any commercial LP release of the same recording. A close second is a high rate DSD (DSD128 minimum) transfer straight from the tape. I get annoyed by the surface noise of LPs, the distortion esp. towards the end of a side, the wow due to an off center spindle hole, the compression often applied during mastering etc. Vinyl lovers tend to overlook these imperfections, but they are really annoying once you get used to formats that don't have these problems.If most if not all masters from the past 30 years are digital
What advantages does vinyl has vs digital ?
