quite a challenge for a million dollar system......
the price of the system brings gold to life
to make a meaningful horn system one should hornload fullrange and not mix principles for integration and dispersion control purposes
IMNSHO
then there´s be and there´s be, how it´s applied and suspension etc.....
What I had in mind, actually, is 1) Diesis Roma with another pair of open baffle woofers on top, or 2) Diesis Roma re-formatted into a four column system with smaller mid-bass woofers above and below the horn driver, and with three of the current large woofers in a vertical array in a separate tower.
Why would someone complicate a simple horn design with MTM dappolito stuff?
Just because Rockport Arrakis sells for 200k plus and you got that bee in your bonnet from there?
How many successful Dappolito designs did you listen to?
I was trying to suggest to you what could, in theory, possibly, maybe convert me to horns. I'm not trying to persuade you of anything.
Not a big complication – – just patch in and bolt on two more woofers.
I am a line array person. Not that I can hear the difference, necessarily, but it does not make theoretical sense to me to have low frequencies coming out of the bottom of the cabinet and high frequencies coming out of the top of the cabinet. At least the D'Appolito makes things vertically symmetrical, and generates a seemingly truer point source.
Off the top of my head:
Rockport Arrakis
VSA VR-11SE Mk. II
VSA Ultra 11
VSA Endeavor E-5
Evolution Acoustics MM7
Gryphon Kodo
PBN M777
Goebel Divin Majestic
Goebel Divin Noblesse
Are these your favourite speakers having heard them in good conditions or are these just expensive Dappolitos?
I feel that some Bonzo line of logic is gearing up, something like "since you haven't heard what you're talking about, and thus you cannot prove to me on data points that it actually sounds better than what you have heard, the D'Appolito array for horns idea makes no sense."Are these your favourite speakers having heard them in good conditions or are these just expensive Dappolitos?
I thought each of these sounded good in the systems and environments in which I heard them.
I hit the brakes for both speaker types!Design Bias is obvious everywhere ..!
When Ron see’s a linesource or panel speakers he hits the brakes and has to sit down, for a taste..
Pretty much like you when you see a horn design ..![]()
Rockport Arrakis
VSA VR-11SE Mk. II
VSA Ultra 11
VSA Endeavor E-5
Gryphon Kodo
PBN M777
But are the woofers paper like PeterA?View attachment 122698
tweeter/mid on top....midbass below......subhorns out on side....not D´Appolito, but same idea
I have several favorite tracks. And I play each of them endlessly.That’s Ron’s favorite track. He plays it endlessly according to him.
A million dollar system? Mine? No.quite a challenge for a million dollar system......
