That is a very insightful observation!You will just buy everything with "tube" in its name Ron !![]()
Unfortunately this thing apparently does not actually take a tube!
No. The AVAAs are great. I still would like a fourth one.Is this instead of your active devices Ron ?
Yes, but isn't this countered by softening of the brain?Research has indicated that as we get older, there is a slight hardening of blood vessels in our ears which sets up resonant peaks in the frequency range that is annoying- 2-4K and higher.
If only it was just the brain that went soft.Yes, but isn't this countered by softening of the brain?
These modes are more likely the length and width of the room related. You will get other complex modes taking the height dimensions. The length and width usually cause the lowest frequency modes as these are the longest dimensionsI just realized a question:
I have two room modes, one at 45Hz and one at 60Hz.
One pair of Helmholtz resonator TubeTraps is tuned for 45Hz and the other pair is tuned for 60Hz.
Part of the ceiling is 9 feet high, and the other part of the ceiling is 14.5 feet high. One part of the ceiling is causing the 45Hz room mode and the other part of the ceiling is causing the 60Hz room mode.
How do I figure out in which corner of the front wall does each pair of tuned resonators get located?
Can I assume that the 9 foot ceiling is generating the 60Hz bump, and that the 14.5' ceiling is generating the 45Hz bump?
Thank you.The length and width usually cause the lowest frequency modes as these are the longest dimensions
find a nice double bass or cello recording with lots of growl and play around with it. something that got too thick as you pushed it before. especially the transition from behaving to breaking up. see if you can improve that musically. find something digital to allow for speedy A/B's.I just realized a question:
Your room is a square? That is geometrically the worst shape for a listening room.Thank you.
The length and the width are the same on both sides of the room. The only asymmetry is the ceiling height.
No, it is a rectangle. The front wall and the rear wall are the same width; the left sidewall and the right sidewall are the same length.Your room is a square? That is geometrically the worst shape for a listening room.
Ok, not what I was talking about. The long wall is likely responsible for the 45 Hz mode and the short wall the 62hz. These are standing waves based on your room length and width. There will be other modes related to ceiling height but it gets complex quickly.No, it is a rectangle. The front wall and the rear wall are the same width; the left sidewall and the right sidewall are the same length.
So does this mean it does not matter in which corner I put which pair of tuned TubeTraps?The long wall is likely responsible for the 45 Hz mode and the short wall the 62hz.
Please also check for negative effects of leanness or loss in energy
Hmmm...interested to see what you find!So does this mean it does not matter in which corner I put which pair of tuned TubeTraps?
No doubt the vinyl's piano "banging" is accented. The tone richer throughout especially the mid-lower range. Her voice is very thin in both recordings however. I'd say I enjoy the piano much better on vinyl. Thank you for sharing.Carole King "Natural Woman" tape
Shure MV88
Carole King "Natural Woman" vinyl
Shure MV88u
Ron, have you considered putting one of each type into each corner, i.e., the 60 Hz tuned TubeTrap on top of the 45 Hz tuned trap, or the other way around?
What does Art Noxon at ASC say?
As for the old traps, have you tried putting them in the back corners of the room? (Honestly, I forgot what your room looks like in the back, if it even has such corners or if it's more of an open layout.)
