No, not yet. This trip was specifically to trying out the bridges and hear the differences. No time to do much else.By the way, have you had a chance to listen to the Dual Ultra?
Besides it might be too tempting .. stick to baby steps!
It is a pity that MacOS is not supported.Ah didn’t know they updated their webpage already. Yes this is the new version.
I heard from Jord. This is a new version of the basic bridge. And although it will fit into the streamer, the Ultra bridge is still a few months out.Ah didn’t know they updated their webpage already. Yes this is the new version.
Although the pic is the older bridge still.
Work in progress
I faced the same situation and took the plunge. It is definitly better and the PF stylus program is much nicer to use and its sq is great. Although I end up using roon most of the time as my partner prefers itI am kind of sad Pink faun owner of 2.16X Ultra. I was going to try Euphony but I have to pay the subsription, in 2.16 Ultra it is already installed in it and you do not have to buy the subscription anymore. When I bought the unit, I was told it is modular and future proof that it could be upgraded in the future and that was one of the reason why I bought such an expensive streming transport. Well it is not the case with my unit. I was told that the only way is to trade my unit for Ultra version, cost more then 10000 euros. Any thoughts if it is worth it to do this trade?
Now of course there is a new usb card coming...
That seems a good plan !I have the 2.16x unit also. My plan is to get the new USB Ultra card once it’s ready and ensure it has a good external 5V power supply. The card is will fit the 2.16x but needs a minor mod ( remove top tab) which can be done at PF.
From my experience switching usb cards and using internal and external supplies, I feel this is an area of streamer weakness that offers significant improvement value if done right.
I guess one day I will also switch to the Ultra streamer and the USB Ultra card will still fit so it’s a good temp solution.
Hi Gunnar,I am really interested in this thread. The Ultra or the Extreme.
A question. I heard, that a sub supplier to Taiko is Pink Faun. Correct? I don’t remember from where nor what parts.
My project for this year is upgrading my power cords. Next year my plan is to replace my old Melco N1Z. I see two main option. Just replacing it with their top version or make a “bigger” change. This second option is also to replace my Naim streamer at the same time. Meaning going for the Ultra or the Extreme and a DAC. I don’t think it will be a huge difference in price between these two main options. But believe that to replace my streamer with one of these two streamers would add sonic value.
I have not heard nor seen any of these two streamers but believe both are really good. I have a Lan cable from PF and their modified Melco S100 switch. That switch really impacted the sound. Right now without hearing these two streamers I would initially try the Ultra due to my positive experience buying from PF (and Farad) .
A question to @Bobbi . Dual Ultra is what?
No, not as far as I know. PF is not recommending Melco S100 as a switch. I am fairly sure they are neutral in switches. The reason I went for the PF modified S100 where all positive comments on WBF. I bought the ”complete“ package from PF. PF sourced the S100 themselves. They provided also the two Farads Super3. So one invoice. Guarantee 2 years on everything.Hi Gunnar,
I read you are using a Melco S100 modified by Pink Faun. Can I extract from this that PF recommends the Melco S100 nowadays. Thanks.
