I have never read anything to suggest that Symphonie Fantastique is not AAA. It sure sounds AAA to me.@Ron ,
I have Reference recordings going back to early 90’s all Digital , how early are your recordings ..?
I have no idea. I never had Golden Cross.Ron, do you find these “newer” Cardas Clear xxx designs still have what was to some, the classic Cardas smoothness that seem(ed) to be present across the entire frequency range?
I was using a Cardas Clear for phono cable duties for a while. I found it to have a bit less of the classic Cardas flavor of that time.I have no idea. I never had Golden Cross.
From reviewer reviews and consumer reviews it seems like Clear Beyond does not have that classic Cardas smoothness. Wherever Clear Beyond is on the spectrum (I suspect quite neutral) Clear Reflection is a step or two smoother -- according to Angela Cardas herself.
That would be consistent with my understanding.I was using a Cardas Clear for phono cable duties for a while. I found it to have a bit less of the classic Cardas flavor of that time.
And so the cable set-up now is Cardas Clear Beyond for sources and preamps; Cardas Clear Reflection single-ended for pre-amp to Jadis amps; Belden 1192A balanced for pre-amp to Gryphon woofer tower amps.
Ron, have you tried switching the Cardas clear reflection with the Belden So that the Carlos goes to the woofer towers and the building goes to the amps? If so how would you describe to change and sound?
CABLES
This is awesome - I like this!!! You never know for sure before you actually try it. Great it worked out.I believe in giving credit where credit is due. David Karmeli was one of the very few people who suggested that one cannot assume that one will have a noise problem running 50 feet of single-ended interconnect.
He was correct.
/ Jk
This is another instructive episode proving that too much dogma is harbored in this hobby by people who mistake subjective opinion for objective fact.
He was correct.
You are correct here. But the skepticism was not about preamp output impedance matching.It really depends on . . . your preamp and its ability to drive in it's output stage.
The skepticism was that 50 feet of single-ended interconnect was inherently asking for a noise problem.
It was "Pleasantville" in my system. I think the Audience i gave you to try will be more synergistic, but we shall see. Cables are so system dependent.I have no idea. I never had Golden Cross.
I am still looking forward to trying the Audience!It was "Pleasantville" in my system. I think the Audience i gave you to try will be more synergistic, but we shall see. Cables are so system dependent.
you mean the ones who try to straitjacket people into theories?
