IMHO one good stereo amp would work.
Maybe he was referring to money. How much to make them sing.
Pick your poisonMaybe he was referring to money. How much to make them sing.
Lucky guys!
Are you suggesting manufacturers like Boulder, Gryphon, and Dan D'Agostino need not apply? Please explain quality vs pure power?Quality amps vs pure power would be my choice.
congrats TLi, very happy for you. your super system takes a big step forward. it will have to sound awesome!!!I ordered a pair of M7, expected delivery date is March/April 2024. They will be driven by a pair of Kondo Kagura 2i tube amp, 50W per channel. They are currently driving my M6 and I am very satisfied with the performance.
I used many different amps, both tube and solid state, on M6. They included ARC Reference 250, Passlabs Xs250 and Constellation Hercules II. The current Kondo tube amp sounds best.
My impression of quality amps vs pure power is good speakers like M6/M7 carry high resolution. All the good and bad characters of amp is fully presented. Good speakers also have good dynamic and bass expansion, so they doesn't need raw power from amp to boost just that. Raw power often, not always, has less detailed sound. I have tried several high power tube and solid amps and finally settle with a moderate power tube amp for its refined sound.
Those are beautiful amps! What will the lowest impedance be for the M7? I guess it all depends on seating distance, room size, and type of music. I typically listen at 80-85 Db and rarely go over 40-50 watts but it does happen. I do believe in adequate headroom.driven by a pair of Kondo Kagura 2i tube amp, 50W per channel.
WOW! These pics give some better idea of the size of these new speakers. I really like the overall shape and scale for more typical listener room sizes. The M9s really demand a sizable room, the M7s ought to play well in somewhat more modest spaces (like my room).
The impedance curve for the Magico M2 is nasty, with dips to 2.3 Ohm:
Be careful sometimes efficiency is exaggerated. An 8 ohm speaker measures a distance of 2.83 volts/1 m (1 watt of power) and a 4 ohm speaker measures 2.00 volts/1 m. If the datasheet says 2.83 volts/1m for a 4 ohm speaker, then you actually have 2-3 dB less efficiency.So always pay attention to the manufacturer's information on how measurements were taken.This is very interesting to me: 50 watts on a 92dB, 4 ohms large, full-range speaker with four big drivers to control and high order cross-overs to penetrate. A priori I would have thought that this is not sufficient power.
But I would love to hear Kagura on them! Based on my recent Jadis experience I think JA200s also would be very interesting.
I love the idea of high-quality tubes on Magicos!
I assume a manufacturer's reported speaker sensitivity is the highest number it reasonably could get away with.Be careful sometimes efficiency is exaggerated.
in the interview I asked Jeff Fritz what is the lowest value to which the impedance curve dips across the frequency range. He said he was not aware of any significant dip below 4 ohms. (Of course this was not a conclusive reply, because he might simply not be aware.)
You need to look at the impedance curve of the speaker 20hz - 20khz then you will know whether that is correct. Measurements are facts that can be relied upon if they are taken correctly.I assume a manufacturer's reported speaker sensitivity is the highest number it reasonably could get away with.
Exsample mesurements reveals a lot about the speaker. The blue line that I drew shows the impedance curve 4 ohm in the audio frequency band. The impedance peak in the bass says that it is a sealed speaker. A bass reflex always has two impedance peak,the tuning frequency (port) and fs resonance from the bass. the peak at 2khz (red marked) comes from the inserted fliter and transition to the tweeter. If someone listens to this with set tube amps, I would smooth it out with an RCL element, because otherwise it plays much too loudly in the 1khz-4khz range. The ear is most sensitive at the point. The peak in the bass is not critical for the ear.That says a lot from those comments.
It is clear from Atkinson's measurements of the M2 that he was talking out of his hat or disingenuous
