All the parts have arrived for the smaller cheaper model.
I just love two-way designs.Ps why would it have to be a 2 way ??
A system / room i always looked up to was this system , it played koyaanisqatsi / prophecies on you tube.
(I dont think it was played through the speakers )
I thought id make a vid playing the same music through my system .
If i would change / upgrade it probably would be Gryphon Apex or Robert Koda
And the best Rock and Roll band of all times AC DC Live wire with Bon scott .
The dirty work .
+ - 2 ,5 db over the 300 hz - 8 khz range 1 / 6 octave smoothfactor
You can never make filter adjustments by ear and achieve these FR results .
Not even golden ears.
Ps around 35 hz - 3db is what i m getting max out of these.
What are the speakers
Can you advise on what measuring system you are currently using ..?
Regards
