I had, the Oppo is good, but my Accuphase transport sounds with more body and gives more detail in instruments like strings and drums.
lloydelee21-My Oppo 93 does not have BNC. Did you have your 83 modded for BNC?
Thanks lloyde. I will try that. Any heads up on adapters?Hi MJim, no i use an adaptor on one side and go BNC into my DAC where (other than i2s) the BNC is widely considered the best input. that said, it can be done, but apparently it needs a little work to do it. i forgot the explanation, but it can be done if you wish.
Thanks, yes very much.Hi MJ,
I have a 'plain vanilla' adaptor for the moment, but was originally going to use Purist Audio adaptors. Hope that helps.
I am auditioning the MSB Technology UMT which is, at it's core, an Oppo 93. For SACD playback it sends out a 24/176.4 stream over all digital outputs. I have it hooked up to the Bricasti M1 and I'm rediscovering my SACD collection. I've been told a stock Oppo 93 will output the same 24/176.4 signal as well.
On a brief tangent, The UMT is an impressive piece of gear. On Redbook playback it was easily as good, if not better, than the Accustic Arts tranport I've been using the past 4 years.
If someone is set on an Oppo, give the new Cambridge BDP (651 and 751) a look. They are based on the same Oppo transport, but made with better parts. Better PQ and SQ.
I assume you are referring to the 93 and not the Ess Sabre dac's in the killer 95![]()
The 95 is more in line with the 751 (price wise).
Perhaps the 651 is more comparable to the 93.
The 651 is based on the old Oppo BDP-80.
IIRC, the 751 has some problems with higher-resolution formats unless it is hooked up to a hi-res video display? It's commented on in some of the reviews.
Nice review, but as with comments on site, how it compares to a 93 or an older SE is better than nothing but totally meaningless if your looking for an upgraded base player, IMHO of course.
Never read a review with what you have said about the 751. Care to back up your claim?
