Are you preferring the sound of the Jadis amps to the VTL monos? If not, then I am not sure why you would try another Jadis.My original plan was to try NOS Siemens in the JA100s. But then I learned the JA100 is optimized for KT90.
NOS Siemens or RFT EL34s are the only EL34s around in a quantity of 20 -- if I set my sights on JA200 Mk. IIs calibrated for EL34s.
If you insist on PP instead of SET, then a CAT JL2 signature is a very good choice as is the VAC PHI 70 (300b PP).
