Could you be any more condescending ?
I did not read Peter's post that way.
I already have …Ron seemed to appreciate the post based on his response. Would you like to add something constructive to the discussion?
No, they are not! Sorry, out of context this statement can be extremely misleading. A fixed parametric equalizer modifies the frequency spectrum in a known way, cables do not do it. They modify the sound by other means, but their action depends a lot on the system.
What has Ron’s response got to do with my interpretation of your post ?please see Ron‘s response.
Yawn … So transparent … So tedious …What does your post have to do with the discussion? You come out of the blue from nowhere to make a snide remark disrupting an interesting conversation. It seems personal and in my opinion, is quite a strange comment.
Ron is musing about how to improve the sound of his system. He is sharing his thoughts. By asking him questions, he shares more details about what he is trying to achieve. It’s a pretty good discussion which may lead to other suggestions.
In my experience, it helps to understand what it is you’re trying to improve so that you can gauge progress with targeted experiments in search of a specific solution.
Asking questions to advance the discussion, in my opinion, is not condescending.
Manual says 5-7 feet in front of wall, i have moved them around a lot ( not an easy task) and ended up 5,5 feet from front wall, i little further into the room than the MBL's prefer.True. But I just would never cut off and then try to re-terminate Cardas Clear Beyond connectors. I virtually never sell anything, but that certainly would kill the resale value of those interconnects. Belden and Mogami I am happy to re-solder! (I have plenty of soldering experience from my Heathkits and amateur radio days.)
By the way, how far in front of your front wall are your ML electrostatic panels presently?
No, because without a direct comparison to an alternative interconnect I don't know what the current interconnects are "doing" sound-wise. They sound fine to me presently -- but that is in a vacuum.
This is where having a reference pays off.
I agree that a reference helps in a situation like this. To be fair, Ron just assembled the system and might not have had another cable that length with which to compare.
Of course you may be referring to the reference of live acoustic music. And I can see that also serving as a reference in this case against which one can gauge the sound of the system.
When comparing two wires or components to each other, I always ask myself which one comes closer to the reference.
Interesting. The Pendragon panels I think are 8 feet in front of the front wall.
The stat panels play down to 200 hz like your ribbons, but the 7,5 inch oppen baffle drivers next to the panels play down to 55 hz they are most likely the main reason for the placement. Without a active crossover they play down in the 30 hz region, but sound too loose in the bass for my taste. I tested them that way to find out how transparent the reworked last generation X-model crossover is, and could hear no difference in the treble midrange region with or without active crossover . Anecdotally i blew a fuse and had to use my early model crossover, that looks identical for a few days, and some of the magic was goneInteresting. The Pendragon panels I think are 8 feet in front of the front wall.
Have you scheduled the visit with Jim Smith yet?
Perhaps you might want to consider cable experiments after Jim works with your system and room.
(...) Of course you may be referring to the reference of live acoustic music. And I can see that also serving as a reference in this case against which one can gauge the sound of the system.
The clear beyond is the first Cardas cable that I like. It is really reference quality.
how do you conciliate your need to be closer to the real reference and the need to maximize differences?
Surely the best way to let our biases decide for us. IMO high-end stereo is so much different from real music and so diverse between recordings to allow such exercise in a reasonable time, unless you focus just on a few recordings and decide all else are poor recordings. IMO selecting components or cables also needs some analytical experience.
BTW, how do you conciliate your need to be closer to the real reference and the need to maximize differences? Many times times they play against each other.
