Hi Ron,
The RD75 is indeed a planar magnetic design and not a true ribbon. A ribbon is free standing and moves easily (you can blow in it and moves around) and only supported at the ends; however, a ribbon can be pure foil or traces on plastic. A planar magnetic driver is clamped on all sides and under tension like an electrostatic panel. This restricts the range of motion and planar magnetics can only be plastic membranes with a metal trace either etched or glued onto the plastic membrane and this acts as the voice coil.
A ribbon driver has magnets in rows on either side of the ribbon so that the ribbon is always immersed in the magentic field. A planar magnetic driver will have either magnets behind the membrane/voice coil or will have magnets on both sides of the membrane/voice coil to create a push/pull design. The RD75 has magnets on both front and back. Old Apogees were a hybrid where the mid/high was a true ribbon and the bass panel was a planar magnetic...same with Magnepans that have a true ribbon tweeter...Diptyque, Alsyvox and Clarisys are all hybrids in that sense. Eminent technology is all planar magnetic I think. To the best of my knowledge, there is no speaker that is a true ribbon over the full frequency range.
Cheers,
Brad
Thank you very much, Brad!
This gives me an idea: I think somebody should produce a field coil magnetic planar driver or a field coil ribbon driver.
We have seen the positive reports about the DaVA cartridge. I have heard what field coil does for the Wolfie and for the Songer.
Why not a field coil magnetic planar or ribbon planar dipole? I bet the sensitivity of the speaker would go up!
