Right. I don't even know when it will be shipped, and how...No email.
God, DG online really are bad at this.
Sure, as soon as I receive both, I will let you know. I think Zoetrope bought DG Mastercuts and is very pleased[please forgive my poor English]
As I know very, very little to vinyl,
what are the differences to be expected between an Original Source vinyl record (approx. €60), and a Master Cut one? (€440 !)
Original Source: https://www.the-original-source.com/
Mastercuts: https://store.deutschegrammophon.com/p30-i2698
I understand that a) Mastercuts (MC) are one degree upwards in the production chain, and b) these have been produced "by the hands", one after one, by a technician, as no automation seems possible here. If I understand correctly, for each MC sample to be produced, the technician has to rewind the tape from the beginning, then start to produce a new MC sample again, then loop through that process.
Am I correct?
What will be the sonic differences? (if Rotatoubib can help, as soon as he's got his records - thanks)
AFAIK, the lacquer is cut directly from the two track master tape or two track mixdown of the session tapes (the chosen takes) or possibly a spliced together multitrack tape that is being mixed directly to the lacquer. This would have to be a limited release, since each lacquer would have to be made individually running the master tape in real time. Normally, a studio wouldn't allow more than a very few plays of the master tape (probably not more than a few dozen) since the master tape gets a bit of wear every time it is played. My understanding is that lacquers are more fragile than vinyl copies, and have a more limited lifetime of number of plays. An alternative which Mike suggests is that tape dubs of the master could be made and sold, for roughly 50% more than the selling price of the Mastercuts (say 650Euros). That would be quite attractive and could generate a similar profit, with the added cost of the tape to make the dubs. Probably easier than cutting lacquers.[please forgive my poor English]
Am I correct?
DG as a label was never known for the quality of its recordings. As I recall vaguely, not one DG recording appeared on Harry Pearson’s Super Disc list in TAS, in contrast to scores of Decca, EMI, Mercury Living Presence and RCA’s. That said, DG obviously had some great conductors and orchestras in their repertoire and it’s hard to not be impressed by the quality of their vinyl from the 1960s and 1970s.DG Original Source
I am happy see new AAA series from one of the cornerstones of classical recording labels.There are four titles as of now, all mastered by Emil Berliner from original 4 track tapes. They say all of them will be on 180g vinyl and in deluxe gatefold with original covers. The records are limited and numbered and cost 35euros. No extortion prices and I am happy to pay that sum for clean AAA copies of good performances.
The first four titles are as follows;
Carlos Kleiber & Die Wiener Philharmoniker Beethoven: Sinfonie Nr. 7
Claudio Abbado & London Symphony Orchestra Stravinsky: Sacre Du Printemps
Emil Gilels, Amadeus Quartet & Rainer Zepperitz Schubert: Klavierquintett A-Dur “Forellenquintett” D. 667
Herbert von Karajan & Die Berliner Philharmoniker Mahler: Sinfonie Nr. 5
The email newsletter I got states that the series will continue for 14 albums which will be released over the course of 2023 but they’re maybe a typo there. Let's hope not!
Indeed, I have most of the MasterCuts. They are metal lacquer discs, not vinyl.Sure, as soon as I receive both, I will let you know. I think Zoetrope bought DG Mastercuts and is very pleased
Is it the LvB7 that’s 3200 copies? I remember it was presold out for a while.
it s left arm…A couple that spring to mind . In spite of HvK’s somewhat alarming conductorial cover pose:
View attachment 111219View attachment 111220
- Original Source is a regular vinyl nothing special but high quality preserved on every stage of manufacturing. It’s cut from the master tape then the vinyl is pressed after 3 step (father-mother-stamper) plating process. That’s it’s disadvantage.what are the differences to be expected between an Original Source vinyl record (approx. €60), and a Master Cut one? (€440 !)
I’ve seen varying quality with the Mastercut albums. One had too much noise and was replaced. Others had what looked like fine scratches or fingerprints on the surface (not sure if they were actually fingerprints or not). Doc said he “wouldn’t rest” until he identified the root cause, but hasn’t replied in months. That said, nothing is perfect, and they did replace the noisy album right away. I think what Supersense is doing is commendable as it’s great to have the option of owning a lacquer for a high but not crazy price.- Original Source is a regular vinyl nothing special but high quality preserved on every stage of manufacturing. It’s cut from the master tape then the vinyl is pressed after 3 step (father-mother-stamper) plating process. That’s it’s disadvantage.
- Master Cut is a lacquer not a vinyl. It’s cut from a copy of the master tape not “the master tape”. On the other hand there is no additional process after cutting lacquer on a Neumann lathe. That’s it’s advantage but using a copy of the master tape is an important disadvantage.
