try this setup in your room. works well in 90% of all rooms without investing a lot of money in room acoustics.What is the ideal distance for speakers to be placed away from walls to eliminate the smearing effect of early reflections?
In a perfect scenario, is the middle of the room the best place?
Thank you
Installation guide for loudspeakers by Joachim Gerhard - Suesskind Audio
Joachim Gerhard has put more than 50 years of experience with loudspeakers into this set-up method in order to achieve the best possible sound.
he has been building loudspeakers for 50 years and is a lecturer at a university in the field of acoustics. it doesn't cost anything just try it, trying makes wise
