AudireWhile you are certainly entitled to your opinion, I respectfully disagree with most of it.
First, to my ears the MSB Select II sounds too analytical. While it gets very close to real music it doesn’t seem to have the same level of genuine warmth and soul as vinyl does. This said, it’s still very very good, but to my ears EMM Labs DA2V2, Ideon Absolute + Time, Vitus Masterpeice, and now that I’ve listened to a friend‘s Lampi Horizon all sound better to me …
Second, IMO, it’s disingenuous to say a properly set up digital rig is 30% away from a properly set up vinyl rig. If one’s digital is properly set up then it can sound like a different Cart on a vinyl rig. While they may sound “different,“ I wouldn’t use the word “better“ to describe one over the other.
Third, I don’t like digital records either. So, here we agree.
I am distributor of Vitus Audio in Iran and I love Vitus Audio Products but in High End no Equipment is bright or analitycal. MSB DAC is not analitycal and MSB in proper setup is OK.
I remember my friend listened to CEC DAC DA3.0 and told me CEC DAC is bright. CEC uses MSB dac module and Thrax Audio designed CEC dac for CEC company. I visited the system and said I hear some compression and I said it seems there is signal clipping between DAC and Pre. My guess was right because the CEC output voltage was 6.5v rms and the Pre input range was less than 4 volts rms.
if you hear bright analitycal sound from MSB you should be smart and find the problem , no DAC is bright.
Audio is a complex game and without right analyses all judgments are wrong.
Expert/smart audiophiles like david can help us for better analysys
