Fiber vs. Ethernet sonic differences
Why do you need these exact specs?
Because this looks more like the ones you use for cabling in data centers, enterprise networks, telecom rooms, server farms, cloud storage networks aso where you need km's of them and bend insensitive ones are required for saving space.
Because grade B is the best standard:
and "bend insensitive":
And with APC connectors then you have the best.
Torben
PS: Please note that Grade A is not approved jet.
Reactions: MarcelNL
Torben
From what I read about APC vs UPC made me think the decision is driven by the SFP module and somehow I concluded UPC is what is used, am I wrong there?
Actually using Corning with UPC B grade connectors with my Finisar 1474 BTL FSP modules...so do I need to order some B grade (they actually use A ) APC ?
Hi.
So far I found no Corning with UPC B grade connectors - I only found this:
But there is no information about B Grade.
Where did you find Corning with UPC B grade connectors?
If you look at APC:
APC Fiber Connector - Angled physical contact connectors are designed to minimize the back reflection even more efficiently. The ferrule end-face of these connectors is polished at an angle of 8 degrees. Thus, any light that reflects at the point of termination is reflected at a steep angle so it cannot travel far towards the source. in other words, this polish style forces the light to reflect into the cladding rather than the sources.
So compared to UPC, APC would be an improvement.
I think APC would work fine with Finisar - but again I don't know much about Finisar.
PS: "(they actually use A )" - I am not sure what you mean. "A grade" has not jet been released.
Torben
Reactions: TRHH
Product Highlights
Offered in PVC/OFNP Flame-retardant Jacket
Available in Standard LC/SC/FC/MU Grade B Connectors with 0.12dB Typ. IL
G.657.A1 Bend Insensitive Fiber & 10mm Min. Bend Radius
PVC (OFNR) Flame-retardant Jacket
Grade A Precision Zirconia Ferrule Connectors Ensure Low Loss
TIA 604 (FOCIS) & IEC 61753-1 Standard
Designed for Long-haul 1/10/40/100/400G Networks
guess those connectors are labeled as grade B because A is not yet official (so I read here)
Reactions: TRHH
there is light at the end of the yellow tunnel, did you look at my earlier post?
sure; https://www.fs.com/de-en/products/61326.html
takes a little while to get made but IMO well worth the wait.
Hi
Have already ordered the LC-UPC cable (it is a Corning SMF-28 Ultra fiber). Will order the APC version later.
The APC version (2 Meter) is roughly 20 EURO.
What I don't understand:
is almost 79 EURO (also APC).
But there is the different?
Torben
IMPORTANT
Make sure that the SFP that you are using support APC as well.
I use StarTech (Cisco Meraki MA-SFP-1GB-LX10 kompatibel SFP Transceiver Modul - 1000BASE-LX) and I did get this information from them:
“Unfortunately, all StarTech com fiber products use UPC connectors, which are not compatible with APC connectors. UPC and APC connectors cannot mate with one another because causes the fiber cores don’t touch. This can cause a degraded connection or none at all”
Torben
we'll see if it supports APC...if it sounds worse or does not work I still have the grade B LC-LC UPC cable in place
Reactions: TRHH
Just installed LC-LC Duplex 9/125µm Corning ClearCurve Single Mode Bend Insensitive Fiber Optic Patch Cable
Torben
Reactions: Republicoftexas69
For some time now I have been using two network switches (Melco N100 and UpTone EtherREGEN) which I connect to Finisar FTLX1475D3BTL with optical fiber PHOENIX CONTACT Single-mode OS2 duplex jumper, LC-LC, UPC polishing 1m.
In the datasheet of both Melco and EtherREGEN as well as Finisar I did not find any mention of connector-socket compatibility.
I also don't know if there will be a difference in SQ between APC and UPC.
If anyone has found it, please help.
I would not get upset over the potential difference, if you're patient I'll let you know in about 3-4 weeks...using te same FSR as you and indeed the spec sheet says nothing other than LC-LC
and, what is the verdict?
Below a comparison of:
Fosco: LC-LC Duplex 9/125µm Corning ClearCurve Single Mode Bend Insensitive Fiber Optic Patch Cable
and
FT: Customized Grade B Duplex Typical 0.12dB IL OS2 Single Mode LC/SC/FC/MU 2.0mm Bend Insensitive Fiber Optic Patch Cable
Torben
Finisar 1475BTL is confirmed to work with LCLC APC - LCLC APC fiber, and it has a small advantage over LCLC UPC- LCLC UPC....eerrr at this level the advantage is not so small I think....
after a night's sleep and permanently installing the wat now is the third LCLC fiber stretch I am rethinking the original verdict...the difference is not small at all, more microdetails are somehow leaving the music more intact, as if a cellist left hand is suddenly adding more vibrato...just that it's not more it's much clearer and cleaner.
now to find a network setup that sounds best...yesterday I removed all other internet connections from the router and put those on a switch and that makes quite a difference.. I was trying to switch off WIFI in the router using a repeater as Access Point but that was handicapped by the fact W11 pro requires WPA 3 and does not tell when the reason for 'no internet' is a mismatch in the security protocol
@MarcelNL - Very interesting. Did you install just a cheap switch?
Torben
