What's Spinning Tonight?
Christmas songs! To acknowledge the 19" of snow we got today (and it's still coming, and a great big rural county snowplow just slid off the road into the ditch on our lot, bad news...)
What happened?
Well my GF decided on her day off to clean the apt and started to clean up my audio stuff. She managed to step on both ICs going into the amps breaking off both male pins into the female connector. And no way to get the piece out so am going to have to order two new male connectors and solder them in. So it looks like the system will be down for a week. Just when Doshi/ZYX combo was starting to sing with the Tele ECC81s (maybe some 801S are in the cards).
Are the females in the chassis hollow from the rear? Y not open the covers & poke Pipe cleaners or tooth picks from the inside out?
Good suggestion but the back of these connectors are essentially sealed and can't do as you suggested. Mark suggested trying to drill it out but upon further investigation, would just damage the hole and teflon inside the connector eg. the male end is too small to really remove. It sucked that it broke off flush and can't use needlenose pliers. I even tried supergluing something to the pin hoping to pull it out but that didn't work either :(
What a drag, sorry to hear it
I still want to see a picture of the broken connectors! I can't believe there isn't a way to get the broken connectors out.
Can you take a needle and bend the end into a tiny hook? You might be able to retract the post by pushing the needle through the center (I assume the pin is hollow on the male connector...) and hooking the end inside to pull it out.
Lee
Tonight this one:
Look at that art work!! CD's today just don't hold a candle on this type of presentation, IMHO:(
Beginnings - Allman Bros Band
I mentioned this album as containing one of the great moments in music for me: the segue from Don't Want You No More into It's Not My Cross To Bear never fails to give me goosebumps. Great one.
Lee
Lee
Good thought but the center pin isn't really hollow. I tried pushing something into it with superglue to pull it out. Didn't work :(
Too bad... How about cooling the connector down so that they both contract a tiny bit? Might produce just a touch of play....
Lee
