What's Spinning Tonight?
Ok Mike; just quote my post and look at how I obtained that cover picture. :b
You Had It Coming - Jeff Beck
Right now:
* Gain set at -4 dB! :eek: ...That is extremely LOUD! :p
[Try to do this with your turntable nearby! And,
you'd better have a goddamn good pulleys system with a good anti-vibration skating absolution!] :b
^ I like the picture cover. ...And I luv everything ECM. :b
____________________
Playing right now:
Jazz on the HD R.a.d.i.o.
Yola - Eleanor McEvoy [SACD 2.0 Stereo]
Playing right now:
* DSD pure bitstream audio signal (100% untouched).
Loudspeakers playing Full Range (-6dB @ 24Hz). No subs, no x-overs, no processing, no nothing.
Pre/pro's overall gain set at -3.0dB
Yes it is Lloyd! Because I have the other CD versions as well. And to my ears, this one is it! :b
And/or unless someone else knows some better versions (LPs & all).
{And indeed, the first two discs of this 3-Disc set are HDCD encoded, with better dynamics.}
Thank you...i checked on Amazon and could not see the HDCD in the description so good to be able to double check with someone who owns the cds. thanks...will try to get.
Last Fair Deal - Rory Block [SACD 5.1 Multichannel]
Playing right now (from the SACD 5.1 layer):
* With my two subwoofers in action, with Audyssey engaged,
and DSD audio mode selected, and without any bitstream downconverssion (of course).
Overall Gain set at -9.0dB [LIVE volume level, and sitting in the third row!] :b
Two new LPs showed up on my door today from Elusive Disc. Shelby Lynne “Just a Little Lovin’” and a limited edition (2500 copies-mine is serial #0821) 45 RPM version of Art Blakey “Impulse.”
