Good suggestion but the back of these connectors are essentially sealed and can't do as you suggested. Mark suggested trying to drill it out but upon further investigation, would just damage the hole and teflon inside the connector eg. the male end is too small to really remove. It sucked that it broke off flush and can't use needlenose pliers. I even tried supergluing something to the pin hoping to pull it out but that didn't work either
