One really good thing Peter B did was to record lots of rooms at shows with a standard level of recording equipment. It was not an iPhone but a dedicated video camera (not sure about outboard microphones). Pursuit of perfect system also used a good Tascam recorder with outboard microphones and while good, IMO are not at the level of Moiz recordings. Peter B. tended to use somewhat unrevealing recordings that sounded pretty decent on most systems but you could still pretty clearly separate the wheat from the chaff with is videos.
Yes, so if it sounds really good on YT then one can reasonably assume it was rather fantastic live.
Moiz audio state on their videos that they use a Pearl DS70 microphone (3750$) and a Zoom F8NPro recorder (1000$). This is a big step above phones and 100$ microphones, and not something Jo Schmo is likeky to purchase just to show off his system on YouTube.True, at least for Moiz. There are others that may or may not be iphone (or whatever) that are also very good. But the ones from Moiz and Prana are darn good sounding.
Pearl Microphone Labs DS70
SURROUND MICROPHONE With two rectangular capsules and separate outputs for all four diaphragms, the DS 70 is arguably the most potent stereo microphone on the market. The Pearl DS 70 is a 4-channel, multi-pattern stereo and surround microphone.www.proaudiodesign.com
Not necessarily. For example, I don't think you can hear some of the nasty little distortions that can be irritating in the room on a video. Also, a YT video only has so much resolution (otherwise we wouldn't need uncompressed high-end digital or analog), thus it may make a less resolving system sound relatively better than it is compared to a more resolving system over the same video medium, and upon hearing that lesser system in person the limits of resolution then may be disappointing.
Moiz recordings are just fancy recordings that don’t allow you to listen to what the equipment is doing but make overall sound good
BSMoiz recordings are just fancy recordings that don’t allow you to listen to what the equipment is doing but make overall sound good
Can you please use technical terms or math, or point us to reference material, that show that compressing audio to 256 kbps AAC can be used as an audio quality enhancer.
Don't get what you mean...This one still amuses me with Peter doing his best ‘ How to exit the aircraft in an emergency ‘ routine
THat's a funny thing about the YT compression...it simply sounds better than other compression schemes from the likes of Vimeo etc. Don't ask me why but it is a clearly better sounding. Will you lose something? perhaps and perhaps that soemthign is unpleasant but I think that is the exception rather than the rule.Not necessarily. For example, I don't think you can hear some of the nasty little distortions that can be irritating in the room on a video. Also, a YT video only has so much resolution (otherwise we wouldn't need uncompressed high-end digital or analog), thus it may make a less resolving system sound relatively better than it is compared to a more resolving system over the same video medium, and upon hearing that lesser system in person the limits of resolution then may be disappointing.
THey are better recordings that allow you to hear more of what the system is doing. It should be pretty self-evident and it is to most...just not you, who wants to normalize to the lowest common denominator. Yes, you can hear a lot with an iphone but it doen't give that accurate of a portrayal of what it actually sounded like in the room. Moiz recordings give you a very good impression of what it was like to be there...I know as I was in the room for some of his recordings.Moiz recordings are just fancy recordings that don’t allow you to listen to what the equipment is doing but make overall sound good
Sweet microphone.Moiz audio state on their videos that they use a Pearl DS70 microphone (3750$) and a Zoom F8NPro recorder (1000$). This is a big step above phones and 100$ microphones, and not something Jo Schmo is likeky to purchase just to show off his system on YouTube.
You are right but when Moiz goes around and records lots of rooms then you can hear that not all of them sound so great and you get to hear pretty close to what it sounded like being there.Moiz audio state on their videos that they use a Pearl DS70 microphone (3750$) and a Zoom F8NPro recorder (1000$). This is a big step above phones and 100$ microphones, and not something Jo Schmo is likeky to purchase just to show off his system on YouTube.
I was not implying otherwise.You are right but when Moiz goes around and records lots of rooms then you can hear that not all of them sound so great and you get to hear pretty close to what it sounded like being there.
Of course you can train your brain to hear through lots of stuff to extract differences between gear in recordings. But it sure is a lot easier to hear the differences when the recording is good.I have discussed system videos offline with Tang, ddk and a few others for quite a while now. They are extremely adept and understand the system and room through these iPhone videos. It is uncanny how they get right to the essence of what a system is doing right or wrong through these videos. These types of descriptions are generally different from what is discussed in these threads. The focus on what to listen for and the value is clear to them and I have learned a lot from discussing the videos with these two guys.
