yeah, we all have to do our bit getting greener ;-)Not four per side
Lots of opinions with very little experience - even anecdotal! - to back it up. Unfortunate.Field-coil drivers, pros and cons. Relics of the past, or still relevant?
I've been thinking about so called Field-Coil speaker drivers lately. Or "electromagnet drivers" as some seem to label them. Do they have any technical benefits that make them worth the extra expense and trouble? Nearly all info I can find online is vague mentionings of their superior "sound"...www.audiosciencereview.com
My understanding of why Alnico magnets sound better is that they are more easily focused into the voice coil gap and also do not sag as much when current is introduced to the voice coil as ceramic magnets; to my understanding neodymium sags the most. I might be mistaken about the latter bit about neodynium but I know it took a while before speaker designers figured out how to use it without making a bad sounding speaker (neodynium had a very bad reputation in the guitar amplifier world on this account...). Field coils OTOH sag far less since they can be powered by a regulated power supply.
@tima I was not implying AlNiCo always sounds better, but it does have lower hysteresis than other permanent magnets. I disagree that AlNiCo has a 'vintage sound'. Speaker magnets are a huge untrodden area IMO, we spoke with Wolf about this and it's mind boggling how much aspects there are that are not 'out in the field'.
Given this, I wonder why field coils have not (yet) enjoyed a renaissance, especially for higher-end speakers?
If the magnetic field sags when current is applied to the voice coil, its a pretty safe assumption that the coil will not move as quickly.Yes, my understanding is that the temporary magnet is better focused in the VC gap and may sag less. My question re sagging is how much does this impact the sound. Neodymium has greatest flux field intensity, so sagging may be less influential than with other magnet types. I will not say a field-coil driver is inherently yields better sound. It has its virtues, yes. We can compare numbers for various parameters, but how do those cash out in terms of what we hear.
Ugh. Audio “Science” Review is the worst forum - pure garbage (although there are a few valuable members). There’s no “science”, it’s just Amir trying to demonstrate -- with false logic and irrelevant charts — why high-end audio is a waste of money.Field-coil drivers, pros and cons. Relics of the past, or still relevant?
Are you referring to the body of the driver, or the coil material itself?Yes @Atmasphere,In a field coil, the permeability is limited by saturation of the material in question, which is comparatively a very high value in a low carbon steel and even higher in (for example) permendur, or iron.
I agree, yet SOMETIMES there is actual information in between the bashing, typically from folks trying to argue against it.Ugh. Audio “Science” Review is the worst forum - pure garbage (although there are a few valuable members). There’s no “science”, it’s just Amir trying to demonstrate -- with false logic and irrelevant charts — why high-end audio is a waste of money.
That's the body of the motor, @Zeotrope . I'm going to be documenting the entire experience of having developed my own drivers and loudspeakers over the past decade or so, in a new expert's forum that was just announced in the newsletter last night. That's here:Are you referring to the body of the driver, or the coil material itself?
Interesting, thanks, looking forward to reading it!That's the body of the motor, @Zeotrope . I'm going to be documenting the entire experience of having developed my own drivers and loudspeakers over the past decade or so, in a new expert's forum that was just announced in the newsletter last night. That's here:
Modern Field Coil Loudspeakers- by Ken Songer.
Welcome to the Songer Audio Industry Expert Forum. Songer Audio is the product of the lifelong passion of Ken Songer, Founder and CEO of Songer Audio. It is the sum of thousands of hours of design and redesign, of refinement and production, and of an obsessive drive to perfect the joyful...www.whatsbestforum.com
I'll be starting out with my design design goals and the development of the field coil motor, in the next post.
The failure over there isn't the measurements so much as a failure to understand how measurements show what we also hear. As a result the right measurements are not always made.Ugh. Audio “Science” Review is the worst forum - pure garbage (although there are a few valuable members). There’s no “science”, it’s just Amir trying to demonstrate -- with false logic and irrelevant charts — why high-end audio is a waste of money.
Yes, totally agree.The failure over there isn't the measurements so much as a failure to understand how measurements show what we also hear. As a result the right measurements are not always made.
One spectacular failure was a review of a PSAudio regenerator, measured with no load as opposed to a simple power cord. To really see what the regenerator could do, a variac (which was on hand), could have been used to demonstrate its ability to regulate the line voltage while under load, and then graph the distortion of the resulting AC sine wave when distortion was introduced to the AC line.
Regarding that, I think we can measure what we hear, but so often people simply don't understand the implications of the measurement including the people that make them.The other problem is that so much of what we hear cannot be measured. They simply go by signal to noise and distortion data. Everything is just "bits", etc...
I'd love to read about that, @Atmasphere , if you have some resources to share that may be helpful. Always looking to learn more, especially regarding the accurate interpretation of measurements.Regarding that, I think we can measure what we hear, but so often people simply don't understand the implications of the measurement including the people that make them.
Distortion is a good example; there's a failure to understand how sensitive the ear really is to higher ordered harmonics. That's why THD and SINAD are not enough; you have to also show the distortion spectra (at 50Hz and also at 1 and 3KHz) and distortion vs frequency
None of it is rocket science.I'd love to read about that, @Atmasphere , if you have some resources to share that may be helpful. Always looking to learn more, especially regarding the accurate interpretation of measurements.
If it measures good and sounds bad, it is bad; if it measures bad and sounds good, you've measured the wrong thing.
I seem to recall Bruno Putzeys coming to a similar conclusion....This is only a personal theory at this point, but as far as I can make out when distortion increases with frequency (and with 99% of amps made with feedback since its inception this is the case), it contributes to harshness and brightness since lower ordered notes can make higher ordered harmonics that are a lot louder than you might expect.
Thank you, @Atmasphere - I had no idea that the ear uses higher ordered harmonics to sense sound pressure! Honestly, I didn't know that lower ordered harmonics mask higher ones, either. My loudspeaker work is pretty straightforward - I look to see if I'm over 1% THD above 50Hz, 2nd-9th harmonics, taking measurements nearfield < 500Hz, and 1M on axis > 500Hz. If not, I'm happy!None of it is rocket science.
It comes from all over! First, the acceptability of the various distortion harmonics is documented in the Radiotron Designer's Handbook, 3rd edition. Fairly early on in the tome IIRC.
It should be common knowledge at this point that lowered harmonics can mask higher orders. This has been known in loudspeaker design for some time. What's less well known is that the 3rd is treated much like the 2nd harmonic in that its innocuous to the human ear (as long as its not too high). We know this from tape recorders, which make a 3rd harmonic as its dominant distortion component if functioning correctly.
So the masking principle is an important part of understanding how this works.
This is only a personal theory at this point, but as far as I can make out when distortion increases with frequency (and with 99% of amps made with feedback since its inception this is the case), it contributes to harshness and brightness since lower ordered notes can make higher ordered harmonics that are a lot louder than you might expect. If they fall inside the Fletcher-Munson bump then the ear will be more able to pick them up.
I also hope we all understand that harmonics give instruments their tone color! What isn't well understood but is super easy to demonstrate with simple test equipment is that the ear uses higher ordered harmonics to sense sound pressure. This is probably the case because pure sines don't exist in nature.
On this account, the ear is keenly sensitive to higher ordered harmonics since it has over 120dB range. Add to that the ear assigns tonality to all forms of distortion (just as it does to musical instruments) and you can see that knowing the distortion spectra, seeing if the lower ordered harmonics can mask higher orders and so on will tell you a lot about how a bit of electronia will 'sound'.
You can see that there's nothing all that complex here.
I think Daniel von Recklinghausen of HH Scott understood a lot of this when he said
