Otari screw on clamp NAB Hub adapters
rockitman
7,096
431
1,210
Northern NY
I have an MTR-10 that I will need the clamp on spindle type NAB hubs. I see machines for sale on ebay that have them but none that are sold separately. The revox/technics style won't work.
Does anyone have a set they want to sell or know of a place that may have a set to sell ? Please PM me the info. Thanks in advance.
otari NAB hold down clampers
I won't guarantee that they will work, but you could try some old Ampex 350/351/440 NAB clampers. They are readily available and could work out until you find some Otari adaptors.
REB
Portland
Just throwing my two cents in here, but have you thought about maybe using nab hub adapters from an Akai reel to reel? I have read that these are probably considered the "best" nab hub adapters to use? They appear to be similiar in style like the Otari's. I can't really say that they are the best because I've never used them. I've only used Teac (which work very, very well) and customized type nab hubs adapters on my reel to reel. But whatever you do don't use or try Pioneer model PP-220 or PP-220A nab hub adapters. I've tried them and had problems with them so I just put them aside for now.
You might try to find a pair of VIF NAB hub holdowns. They come up on Ebay once in a while. I use them and they work well.
Thanks Roger. I did get a set of those on ebay and I also secured two more set's of the Otari's for both my MX 5050 and MTR 10.
Thanks Myles for the Jcorder info too. Looks lkike I won't need them.
