$5400/prwhat s the price? it seems as though Ralph has offered a return for in home evaluation.
I’ve come to understand that there are 2 categories of amp that have the potential to float my boat. One of the key ingredients of the first type is that it has extremely low levels of distortion. I have some of Tom Christiansen’s Neurochrome amps. They are the most neutral and transparent sounding amps I’ve ever heard and that kind of open window on the music has its own set of charms. These DIY amps would embarrass many commercial amplifiers costing orders of magnitude more. The Wolverine amp recently designed by a group of enthusiasts on DIYA may pull off an even better disappearing act, if that’s possible. (I have the PCBs to build the amp.)
The other category comprises amps that have a particular distortion profile, specifically one where the 2nd harmonic is dominant and the higher order harmonics successively decrease in amplitude. I believe the BBC did some research in the 40s or 50s that concluded that this sort of profile was favoured by many test listeners. Jean Hiraga conducted his own experiments and reached a similar conclusion. You’ll find modern day designers who also subscribe to this school of thought. Hugh Dean (AKSA) designs all his amps with this goal in mind and Nelson Pass has even designed a DIY distortion generator which you can use to add variable amounts of 2nd and 3rd harmonic distortion to your audio chain.
So Ralph’s comments about his amps resonate with me and I’d certainly like to hear them. Not sure that’s possible in the UK though . . . .
Hi Ralph… I didn’t say you had said this… this is the kind of comment that has been made in the thread that I was referring to.Yep - there's far too much of that regarding Class D. Many won't even consider the notion. More fool them.
And a blind test will be inconclusive, or consistent with chance. Oh, but in this case, we don't' want to prove everything sounds the same. We want to prove one is better. Otherwise, why bother. I am assuming that is the two hypotheses. Class D is better than tube. Tube is better than Class D. That is, if history is any judge.Unless the comparison is blind perceptual bias/prejudice will likely color the result (either way, pro or con class D).
These amps won’t replace all tube amps in a 10 year period if they can’t ultimately overcome listening bias… they are either clearly subjectively preferable to tube amps or they aren’t.Unless the comparison is blind perceptual bias/prejudice will likely color the result (either way, pro or con class D).
Certainly, those who rely heavily on measurements would not suggest you can't have an opinion, if you have not heard the amp. That is the substance of their argument. That is if you don't hear what measurements predict, it is you who are flawed versus the limitations of their measurements.This has been a painful issue of this thread where much much more than usual there has been the claims and repeated insistence that only already fully signed on new Class D acolytes can be the only ones who know the truth in how these Class d amps are demonstrably better than all tube amps and all the rest of us according to some are apparently fools for not believing and just following suit in processing ourselves into new class d converts.
Perhaps it would be good for Ralph to set up a new year put up or clam up all round Class D is new best amp type challenge.
The amps are very light and manageable. Ralph could reasonably and I’d imagine affordably send a fully burnt in pair to do the rounds at perhaps PeterA, Tima, Ron and MikeL’s for proper objective forum respected home evaluation.
This would be a great marketing opportunity for Ralph given his absolute faith in the inherent superiority of his new amps. The claim these new class d amps are better sounding, more transparent and more musical than any existent tube amp would make them more than fair comparison competition for Peter’s Lamm SET based horn system, Tima and his Atmasphere experience and Lamm gear and previous AR amps and Mike’s sota SS amps and Ron’s top end trad VTL push pull tubes. All four of these well established members have had very real exposure to the sorts of tube amps that this thread claims should be simply not as good or even as musically engaging as Ralph’s Atmasphere new class d amps. Why not simply put this to the test. If these amps are indeed good enough to put all tube amps out of the market within a decade this would be a good and transparent way to allow them to show their stuff and open the conversation up properly. If all the players were willing sign on I am sure Ralph’s amps would get a genuine fair hearing.
I was one of those that decided to stay with tubes (Wavac monos) as for me Atmasphere Class D was too lean sounding...These amps won’t replace all tube amps in a 10 year period if they can’t ultimately overcome listening bias… they are either clearly subjectively preferable to tube amps or they aren’t.
We can’t divorce experience from the phenomenology of experience. That is to say we build expectation and we have retention of experience and we constantly sharp change between these states and that then our consciousness is ultimately modified and reshaped by these experiential shifts.
All amps face these exact same challenges and potentials of needing to reframe experience if they want to shape retention and build new expectation. But to fully meet the claim that they are tube beaters they will have to convince people the shift is actually clearly beneficial. The four audiophiles I suggested are all examples of people who have a range of valid experiences and show they can clearly articulate their experiences… that is all that can really be expected and is what is needed to start to build a broader and more diverse balance of views and data points on the actual listening reality of Ralph’s new class d amps.
…. <omitted>…
A good boat anchor is not inexpensive.My substantive point is I love audio equipment too. without music it would be merely expensive "boat anchors." IMO YMMV
Who said they would make good boat anchors?A good boat anchor is not inexpensive.
The designer said they are as good or better than his own tube designs. That makes for a great discussion don't you think?Not sure why class D amps are compared to tube amps. Wouldn't comparing them to similarly specced SS amps be far more sensible? Tubes do certain things better than non-switching solid state and vice versa, there simply cannot be a universal winner.
Ha!-Yes well the crafty Arnie bribed me with a hair raising scoot around the Valley in his Black Porsche TurboI thought the Infinity amp was the least reliable amp around, until I got an original Blaze Linear 700...
