This refresh looks like it includes Pulse Mode, which may be new to the Degritter but not USC machines generally. Also some ergonomic difference its buttons. Still limited to 120kHz. If you know the Degritter, what other differences from the original version does this pre-delivery announcement suggest?
Availability: later November 2022
Price: ~$2550 $3280 Music Direct
The Degritter is fully automatic, requiring no additional effort after the cleaning cycle has started. Use the free time for listening to records instead of cleaning them.
Simple Water Management
The machine has a convenient removable water tank for replacing cleaning water.
Perfect Touch Buttons NEW!
We have perfected the feel and function of the machine’s buttons. The rotations and presses provide most satisfying feel you will be unable to let go of.
Ultrasonic cleaning tank that’s in Degritter is purpose built for vinyl records. The tank has two ultrasonic transducers on either side emitting 120 kHz ultrasonic vibrations, evenly distributing the cleaning energy across the record’s surface.
Power Drive 2.0 NEW!
Pulse Mode NEW!
Pulse Mode cleaning is a feature offered by the Power DriveTM 2.0 ultrasonic generator. During pulsing, ultrasonic transducers rapidly switch on and off at high power. This gives enhanced cavitation in water, but keeps the average power consumption low.
Frequency Sweep
The driving frequency of the Power DriveTM ultrasonic generator sweeps between 120-125 kHz. This evens the cavitation energy distribution in the water, minimizing losses and giving an uniform cleaning action.
300 Watts
The average power output of all the washing programs is 300 W. This makes Degritter the most powerful ultrasonic record cleaner on the market per liter of water. The higher 120 kHz driving frequency keeps your records safe.
Cleaning water is pumped through a replaceable filter during washing. Continuous filtration keeps removed dirt from ending back up on the record.
Record Safe Temperature Control
Degritter monitors water temperature and prevents it from rising to levels harmful for vinyl records. High temperatures are managed by automatic cooling cycles.
Smart Drying
Records are dried by a flow of filtered air. Both the drying time and fan speed can be adjusted to keep noise levels in check and to prevent static electricity build up.
Postwash Rinse Option
Degritter supports rinsing records during washing cycles with the help of a separate water tank.
edit: update price per Mike L's note below
Price: ~
Degritter Mark II Ultrasonic Record Cleaning Machine
Designed For You
Distinctly AutomaticThe Degritter is fully automatic, requiring no additional effort after the cleaning cycle has started. Use the free time for listening to records instead of cleaning them.
Ultrasonic Cleaning Architecture
4 Transducer LayoutUltrasonic cleaning tank that’s in Degritter is purpose built for vinyl records. The tank has two ultrasonic transducers on either side emitting 120 kHz ultrasonic vibrations, evenly distributing the cleaning energy across the record’s surface.
Pulse Mode NEW!
Frequency Sweep
300 Watts
Clever Features
Active FilteringCleaning water is pumped through a replaceable filter during washing. Continuous filtration keeps removed dirt from ending back up on the record.
Smart Drying
Dimensions
37 × 28 × 21 cm
14.6 × 11 × 8.3 in
Supported Voltage
100 V – 240 V AC
Ultrasonic Cleaning
120 kHz / 300 W
Water Tank
Removable
1.4 L
0.37 gal
Noise Levels
50 dB – 70 dB
