Goebel are really pushing the price envelope, especially given you'd likely want a pair of themFantastic, Gian60...i have been very curious to know more about those. I believe 1 Petite Baforce is Eur72,500? Even by Wilson, Magico subwoofer standards, Eur72,500 for a massive sub is a LOT...pretty much double the price of the Wilson & Magico reference subwoofers.
https://parttimeaudiophile.com/2017...-high-end-from-gobel-ch-precision-and-kronos/
I think we've comfortably passed those.
What sort of music did you hear?I was very impressive from Goebel petite baforce
I had Krell Master Reference and Soundlab mono B1,but this is much better.
Was connected to Aeon Reference speaker,cut at 35 hz,and bass was perfect,very deep and strong,natural,seems perfect.
There is the version passive and the version active,with 8 class D amp,one for each driver.
Really very impressive
Can you remember how much for the big sub?
For non-DIY people are there any commercially available, size-no-object, horn-loaded bass subwoofer products which you think sound excellent?
For example, do you like any of the bass horns offered by Avantgarde or Cessaro or Tune Audio?
Or are you suggesting that conventional, large, non-DSP, direct-radiating subwoofers from companies such as Funk and Seaton are sonically great if one has the space to accommodate them in the listening room?
... Or are you saying that even compared to a giant box containing three or four 15 inch or 18 inch direct-radiating drivers you still prefer the sonic qualities of the horn-loaded bass subwoofers?
I think Jagerst.' s post is fascinating...and from what i have heard, I could well believe FLH are THE way to go.
Unfortunately, for me there is a reason why cones are so prevalent...they take up a LOT less space and with today's excellent designs, they accomplish a lot. The FLH I have seen are HUGE. And from a practical standpoint, that volumetric space takes up a lot of living room space.
When I was investigating sub designers (like Nathan Funk of Funk Audio), I noted that a technical collaborator of his on his 18.2 sub also said his favorite deep bass implementation is Front Loaded Horn design...and that the closest measuring and sounding sub to an FLH that he had heard/measured was Nathan's 18.2, a dual-18" sub.
It's not about the brand per se but instead raw physics/acoustics and implementation, all or certainly some of which Duke with his experience here has covered at earlier junctures in this thread. Where I would differ, it seems, is the bigger scale...
...and, preferably, the particular bass principle necessitated for proper bass/sub playback, or just the one that I cherish the most.
(where I would also differ with Duke is the chosen cross-over region between the subs and mains, with me preferring a higher XO here).
So, one could say my "mission" here is not to proclaim an absolute winner where bass principles go (let alone brands), but rather to maintain that DR's and horns sound different, and between them my preference is clearly for horns.
FLH's are the real deal for sure. I'd urge you to consider tapped horns as well... Well-developed TH's have a clean range of up to 2 1/2 octaves, so I'd advice knowing the LF-extension one needs and use fairly steep low- and high-pass filters.
I have NO PROBLEM with the concept that raw power + good acoustics > good acoustics alone!!! My little four-piece subwoofer system is what it is because that happens to be the place on the continuum where I think I can be the most competitive.
I'm definitely not "married" to the bass enclosure principle that I use, which is a juggling of tradeoffs with cost-effectiveness playing a major role.
The reason I prefer to cross over no higher than 80 Hz is so that subs which are fairly far from the main speakers don't pass upper bass/lower mid information loud enough for you to hear. The subs which are near the main speakers can be crossed over as high as you need them to be for good integration with the mains.
Within its low-frequency extension limits the best quality bass I have ever heard from a single sub was from a horn subwoofer (Edgarhorn Seismic). And likewise the best bass I have heard from a pair of speakers came from horns (Classic Audio Reproductions Hartsfields). Not that my experience with horn-loaded bass is all that extensive, but it has been memorable.
Tapped horns are more likely to be practical than are front-loaded horns if we look at size vs low-end extension, and approach the overall system design while taking that bandwidth constraint into account. ...
... I don't think I've ever heard tapped horn bass. In your experience, how close does it come to front-loaded horn bass in quality, assuming comparable low-end extension?
betonart-audio.de
Yes, really good high efficiency 98db/ 1 watt woofer. Enough power for 40db dynamic impulse. not many subs can do that.Wow this is stepping up your sub game!
I am not sure that the Aeon subs are better, they should be, but in the situation that these are being used, with the speakers they are being used with and at the price point the Sovereign's are just fantastic. If you own a great speaker and want to make it sound even better these subs will accomplish that. I have nothing bad to say about REL or JL as these are both excellent but this is a step above in both performance, fit , finish, ease of use and of course sound. They also cost more !Listened very well this sub
Never listen in my life a better sub,only the biggest Gobel Aeon line sub can do also better,but 450 kg weight is ……
