Hi Marcel,SET in probably it's purest form, one single Tube....the sound of the 2.5W is incredible, detailed, seemingly limitless dynamics, incredibly well controlled deep low end, by far the best amp I ever heard.
My, my, madness? ;-)Hi Marcel,
Please can you update us on your system. I see all sorts of exciting madness occurring. Best wishes.
No output transformer?My, my, madness? ;-)
This is a G2 mode EL519 my best friend is building for me, El519 in G2 triode is the original idea of Cees B where I heard this circuit for the first time a few years ago and after hearing some other mesh tubes it 'stuck'. Here it is used in a one tube design using an input transformer, a mercury rectifier and an enormous choke. The low part count makes selection of components and placement quite critica so we feast our ears using rare and mostly handmade components.
Sounds very interesting. And what speakers are you currently using?My, my, madness? ;-)
that one might sound great as well! Single mesh tube and all that.Voyager - Tron Electric (tron-electric.co.uk)
This amp is also one tube per channel with amorphous core Lundahl output transformers...would love to try this out. It even makes a highly usable 5 watts from the 20B high gain DHT.
My "Trionor' , which is an adaptation of the good old Bionor. Now using three 13"Tesla Full Range drivers. The speaker in the picture is a Klangfilm open baffle with two KL405's at my friends place.Sounds very interesting. And what speakers are you currently using?
Any pics of your Trionor in situ? Sounds cool.My "Trionor' , which is an adaptation of the good old Bionor. Now using three 13"Tesla Full Range drivers. The speaker in the picture is a Klangfilm open baffle with two KL405's at my friends place.
Loving the project that your friend and yourself are working on Marcel, it sounds to be a lot fun that you guys are having , have you ever mentioned perhaps a cleaner coming in once a week to your friendMy "Trionor' , which is an adaptation of the good old Bionor. Now using three 13"Tesla Full Range drivers. The speaker in the picture is a Klangfilm open baffle with two KL405's at my friends place.
Would be interesting to hear an audio vid sporting your more recent enhancements of the two curves respectively .this is from a while ago, meanwhile I did upgrade the DAC, and tweeter and have fully coated the paper. Currently planning to do a head to head comparison of two horn curves since we found out the original drawing is incorrect, and the original Bionor flare is off from the calculations. (posted before in the female vocals thread), this video was posted earlier in the female voices thread;
It is a well established fact that cleaning lady's, and wife's break cartridges ! It is safer to keep the place messy!Loving the project that your friend and yourself are working on Marcel, it sounds to be a lot fun that you guys are having , have you ever mentioned perhaps a cleaner coming in once a week to your friend![]()
It is a well established fact that cleaning lady's, and wife's break cartridges ! It is safer to keep the place messy!![]()
But if you drop anything on the floor you'll never see it again.It is a well established fact that cleaning lady's, and wife's break cartridges ! It is safer to keep the place messy!![]()
My first wife destroyed a Ortofon MC 3000 during dusting, my second wife was told not to clean inside the totally separate equipment room ( i drilled holes in the wall for signal cables). She responded by doing it anyway, lifting up the Nakamichi TT to dust UNDERNEATH it, destroying a Benz cartridge. The lifting of the turntable is probably not possible in the case of the AS 2000 Peter, well maybe only by Keds girlfriend.My cleaning lady has been told not to enter the listening room. My wife enjoys the room but does not go near the turntable.
My first wife destroyed a Ortofon MC 3000 during dusting, my second wife was told not to clean inside the totally separate equipment room ( i drilled holes in the wall for signal cables). She responded doing it anyway, by lifting up the Nakamichi TT to dust UNDERNEATH it, destroying a Benz cartridge. The lifting of the turntable is probably not possible in the case of the AS 2000 Peter, well maybe only by Keds girlfriend.![]()
this is why husbands should do the cleaning, let wives do the listening
