Hi Ariel,
Welcome to WBF!
You are correct, the different Alsyvox models are offered in different sizes to accommodate different room sizes, small to VERY large rooms.
If you look at the descriptions of the different Alsyvox models at this page, the specific room recommendations are listed in each speaker's description. https://alsyvox.com/products/
The external crossovers are identical in size for the Tintoretto and Botticelli, although the internal parts/crossover points are tailored specifically for the respective model that they are paired with.
The Tintoretto and Botticelli use the exact same technology/ribbons/materials etc. The difference is only in the size of the speaker for the different room sizes. The Tintoretto and Botticelli either non crossover versions or X (with crossovers) have the same sonic characteristics.
I see you are located in Israel. Best to email Daniele at Alsyvox at info@alsyvox.com for further information.
Bob
Hi ArielHello,
I really love those speakers, I've heard them in the Munich 2019 show, Wow...
I want to ask please, Is the Tintoretto have the same external crossover vs Botticelli?
Have someone from the forum members have the chance to compare the Botticelli Vs Tintoretto?
As I've understood, it's all about the room size...
Regards,
Ariel
Tintoretto is for smaller room size than Botticelli. As Bob said, these are identical apart size of the drivers. The sound is identical, but Botticelli bigger size gives a bit more dynamic and slam even in a small room.
Best regards
Philippe
Alsyvox | PHPAUDIO
www.phpaudio.fr
