new records should also be cleaned!My lps are all brand new so I never have fort of cleaning them. I avoid second hand lps.
The Autodesk I had leaked, but I gather it was more of a problem with the earlier machines. And then finally, the brushes stopped rotating. I bought the Degritter during the crowd funding stage. It took almost a year to arrive, but I have been very happy with it. When my original machine started to become erratic (the record rotating erratically), I e-mailed the company. It must have been at least two years since the machine arrived, but they offered to exchange it with a brand new machine free, because they had upgraded that mechanism. As promised, they sent the new machine and a UPS label to return the old machine. The only thing that I think can be improved on is the drying function. Blow drying will leave residues on the record. Maybe a vacuum suction wand (perhaps along the slot) to suck up the excess fluid instead ?Replacing my Audio Desk Glass with a Degritter. I liked the AD, it did the job over more than 300 records, no reliability issues at all. What I didn't like was:
- the high cost of cleaning fluid: $25 per tank is crazy. I never clean 100-200 records at once, so I ended up having to buy a $25 bottle of cleaner whenever I had a new record purchase. Degritter costs about $0.50/tank. You shouldn't leave the water in the tank (or in a bottle) for more than a few weeks with either machine.
- the lame filtering action: often water will flow over top of the filter. When I asked AD about this, they sent me an arrogant reply stating it must be my fault!
- no swappable water tanks
- questionable ultrasonic performance: sometimes there would be lots of bubbles, other times very few
- cleaning brushes weren't of much use and probably more of a con than a pro. If I buy a used LP, I will clean it with the spin clean first
- stupid parts pricing: $25 for a sponge "filter"?! Come on!
- arrogant/borderline rude customer service
The Audio Desk is still a great machine, especially for whoever snags mine for half off retail!
The diamond stylus shaves off the vinyl during play. The black is therefore the vinyl dust in the grooves. The 120kHz ultrasound in the Degritter is used for cleaning semiconductors, which is far more delicate than vinyl. It produces smaller bubbles than the 40Hz ultrasound used in the other machines, and can get much deeper into the grooves.Here's something important about the Degritter filter: My records are basically clean. They've been cleaned with other machines and I never see visible residue. After about 20 cleanings (to get very small contaminants out of the deepest part of the grooves) the only thing on the filter was black. i find this very disturbing. The only thing black that has been in the tank is my LP's. This is a long standing concern by some about ultrasonic cleaners, at least about some of them. The black on the filter is proof positive, at least to me, that there is an issue. I'm not knowledgable enough to know if it's the frequency, power, whatever but it's definitely there. I cleaned it and did some more albums I don't much care about. Same thing. Just sayin'. I know many love it but I'm backing away.
I think it's a Pro, not a Con, that you are seeing black in the filter -- it means the Degritter is doing its job.Here's something important about the Degritter filter: My records are basically clean. They've been cleaned with other machines and I never see visible residue. After about 20 cleanings (to get very small contaminants out of the deepest part of the grooves) the only thing on the filter was black. i find this very disturbing. The only thing black that has been in the tank is my LP's. This is a long standing concern by some about ultrasonic cleaners, at least about some of them. The black on the filter is proof positive, at least to me, that there is an issue. I'm not knowledgable enough to know if it's the frequency, power, whatever but it's definitely there. I cleaned it and did some more albums I don't much care about. Same thing. Just sayin'. I know many love it but I'm backing away.
Diamond is used to cut glass afterall.This sounds like serious cartridge misalignment.
Even then, I doubt it.This sounds like serious cartridge misalignment.
Following the suggestion of an expert on another forum; I made 1:100 dilution Tergitol 15-S-9 and keep it in a 500 mL laboratory grade pyrex bottle with wide mouth. I use a 10mL adjustable pipette to draw up 6mL then 5mL (11mL total) to add to one of two degritter tanks filled with De-gassed distilled water (the second is for rinsing, however I find little left to rinse with this mix), the run that through Degass again to mix. I used to add 7mL isopropyl after and again Degass, but have started following the Degritter suggested method of using their fine cloth wetted with 100% lab grade isopropyl alcohol to wipe the record carefully first, run the record through on the medium duration (no dry then, pull tank and replace with the second tank of just pure degassed distilled water), add dry time and intensity and run on medium duration again. This was the process I used when I worried about possible Tergitol residue being left on the disc, however I now skip the rinse tank and note no difference whatsoever.
Note: this mix does foam up a bit on the LP surface, but so does the Degritter surfactant/cleaner at recommended strength so not convinced it is a problem. Also, second Degritter, the first popped then no longer worked about a year and a half into use. The folks at Degritter replaced it under warranty at no cost to me, quickly and without hassle. They make a great product and stand behind it (a rare event these days sadly).
second Note: I too clean brand new records in the Degritter and such not only removes vinyl and other dust from the surface, but also takes away any static charge.
