Introduction of my new Antipodes K50 Music Server
PavelDosko
5
58
thank you for your opinion, unfortunately Rockna NET is a relatively old design (about 6 years) and is based on Roon, which does not suit me
Gjo
270
184
50
What footers are you K50
owners using?
Macattack
222
144
395
SC Low country
For you K50 or K40 owners, are you using an internal SSD and if so, was it a noticeable improvement over a NAS or other external source?
7ryder
203
169
275
owners using?
I have a Symposium Foundation Ultra w/ the optional Rollerblock Module isolation and had some Rollerblock JR. HDSEs that I was using on the server it replaced, so I'm continuing to use these for the K50.
Reactions: Gjo
7ryder
203
169
275
I streamed from a NAS for a long time and found that using internal drives sound better - first with HDD in a Melco N10 and now with the SSDs in my K50.
Reactions: Macattack
Gjo
270
184
50
Have you experimented without the Rollerblock module? Curious.
I have A/V RoomService EVPs and HRS Nimbus Couplers + Risers and will probably use one or the other simply because I already have them.
Reactions: skids929
7ryder
203
169
275
Well, the Rollerblock Modules in the rack are actually a part of each rack support, so essentially, each shelf in the rack is floating on Rollerblocks and I can't really remove those without taking the entire rack apart and putting it back together.
As I wrote previously, in addition to that, I'm using the Rollerblock JR. HDSEs under the K50 and the shelf it sits on.
To answer your question, no, I haven't removed the Rollerblock JRs to see if there is a sound difference.
Reactions: Gjo
Gjo
270
184
50
I didn’t realize the Symposium Foundation Ultra is a rack. I mistakenly thought it was a shelf/platform. Apologies for my rather ignorant reply.
Thanks for the info, though. I have some Rollerblock+ devices, but those are being used under my Esoteric disk player.
7ryder
203
169
275
No worries and not ignorant at all - there are way too many manufacturers and products to keep track of!
Reactions: Gjo
skids929
230
112
113
54
I am using the internal drive, Samsung EVO. I don't notice much difference between it and Roon Server/player
Reactions: Macattack and Gjo
skids929
230
112
113
54
owners using?
I am pondering if I should go with some in particular that existing owners seems to prefer with the k50. I have some of the Edensound sound dampening blocks in a box somewhere I may just throw them under it and see how it goes.
Gjo
270
184
50
I was using a Samsung P7 USB drive for local files. I didn’t notice any difference from Roon server/player.
I say was because I needed to send my K50 in for service because it wasn’t recognizing Samsung EVO SSD drives.
markramler
78
95
370
New York, NY
owners using?
I started out using Stillpoint Ultra SS and changed to the CMS CenterStage 2 1.0. I preferred the CMS footers, they had a more organic and natural sound.
Reactions: 2glory and Gjo
velcro22
13
10
68
57
Canada
owners using?
I use the Isoacoustic Orea Indigo on my Modulum rack. It cleaned up lots of the edges and made the sound more relaxed. Placement makes a difference. Initially I place them under the existing footer but I experienced better result in placing them directly under the box. Still experimenting on best location....definitely subtle changes, not night and day.
(pic below with the Isoacoustic on the original footer)
Reactions: Gjo
Gjo
270
184
50
Most footer instructions regardless of brand/model recommend placement directly contacting the chassis rather than a unit's footers, so your observation doesn't surprise me.
Have you tried moving the Orea Indigos so they're directly under the K50 power supplies (located in the front of the component)?
velcro22
13
10
68
57
Canada
Outstanding! great tip definite and immediate improvement in tone and image position.
Reactions: Gjo
velcro22
13
10
68
57
Canada
On the K50, there is a set of Dip Switches under the case. Anyone has more details? I assume it is for the boot sequence and configuration but more details would be nice. Tks
Gjo
270
184
50
From post #367 in this thread:
Due to the fact that there is no universally agreed to standard for I2S, the K50 has DIP switches at the bottom of the unit for easy access which allow users to change the combinations in order to get it to work with different components.
Reactions: velcro22
7ryder
203
169
275
And they come preset to work with the PSAudio standard
Reactions: Gjo and velcro22
skids929
230
112
113
54
I have A/V RoomService EVPs and HRS Nimbus Couplers + Risers and will probably use one or the other simply because I already have them.tvad
@tvad
Do you have the Nimbus Couplers under your K50? Which size risers did you get? I am kicking the tires on these right now just not alot of good feedback on them and the prices are high so would be great to hear something positive. Obviously I understand every system is different but thes design of these looks promising for alot of component types.
