LOL you’re right, Pillium Elektra could do with more widely available informations. It’s a fantastic DAC though. Very very analog sounding, perhaps one of the most analog sounding I ever heard (not that I heard a lot).i looked for information on your Pilium Electra dac; whether it is 'bit-perfect' or an upsampler. could not find any information. nada. just a reference to different filters.
how does it process any file? does it convert everything to a higher rez file always PCM, always dsd, or keep the file native? is it a hybrid dac where it processes each file keeping it native? native meaning the same as it was originally recorded or transferred from tape. you want that or as close to it as you can get.
if your goal is the best sound, then you should research whether your SACD's are PCM based, or pure dsd. the best sounding file will be the native file if your dac is 'bit-perfect'. if it's an upsampler, then it's less predictable but still likely that the native file will sound better.
maybe the best approach would be to do some listening to various versions of files where you have both choices and find out how your dac reacts.
before you decide how to rip SACD's you need to know where you ought to be going. on your favorite SACD's you may want to go to HD Tracks or another source site and buy the native file? or at least consider it. sometimes Quboz has that native file.
It doesn’t upsample anything, always plays the native file even when I click max everything and disable “native” playback on the setup from Roon, when the file is 44.1K it just play it as it is and vice versa, it also plays everything up to DSD 512 and PCM 768-32 bit, no MQA though.
How do you tell if an SACD is DSD or PCM? Some of my SACD also have DSD logo on the cover but some don’t. Is it safe to assume the ones without DSD logo is PCM?
thanks so much for taking the time for the thorough explanations @Mike Lavigne , much appreciated!
I guess I will have a lot of deleting and re ripping to do tomorrow. Well, it’s almost Christmas anyway, good that I have a lot to do.
