AS Phonolab dual phono preamp
XV-1
3,616
2,625
1,860
Sydney
Gain is:
MM : 38db, 42db, 45db and 48db
MC :58db, 62db, 65db and 68db
Also *if* you use the balanced xlr out you can choose a higher output reference level ( 775 mV or 1.55 V) which could be a factor in system gain....
Audiospecials sell directly to many markets; I would ask them.
Again i would love to send this to some USA based forum members to try out :)
What are the loading options with the Audiospecials phono stage?
Solypsa
1,811
1,400
275
Seattle
www.solypsa.com
Loading options:
MC: 15 20 50 60 70 80 180 250 500 1k
MM: 47k (choice of 60 160 260 280 380 480pf) and 66k (60pf)
There is also a low-gain MM phono card option for higher-ratio SUT users.
Reactions: XV-1
groovemaster
110
234
283
Solypsa, so it is.
The new, AS SUT MM Input offers the following loading options for lovers of step up transformers. Ortofon SPU lovers and others who like Step Ups now get a very specials feature for their AS Phonolab.
100kOhm !!!! 47Kohm / 32KOhm/ 24 KOhm / 20 KOhm / 14 KOhm
In Addition 60pF / 160 pF
Gain is: 28 dB / 31 dB/ 38 dB
So you can vary the sound of your SUT /MC Cartridge combination like the direct MC amping as normally known. Absolute outstanding. I do not know any other phonopre with that possibility.
groovemaster
groovemaster
110
234
283
I am also very satisfied with my AS Phonolab. Of course, with my equipment, my first thought was to buy a Vitus Phonopre. But the AS Phonolab is so fantastic that I prefer to use the money saved elsewhere.
This combination with the Technics GE turntable and the Phonolab immediately appealed to me. A very harmonious combination in a very small space. It's in a music room of a jazz lover. The Phonolab is often found in the possession of creative people such as architects, artists and cultural workers.
groovemaster
Diasoft5
46
20
73
54
40764 Langenfeld / Germany
Oh, I am a chemist. Do I have to return the Phonolab now? ;)
Reactions: Lagonda
Kingrex
2,914
2,393
350
I tried Eric's AS Phonolab. Its a darn nice preamp. It is more clean, quiet, revealing of detail than my Allnic H1201. All around it is a better unit. It is the first of a few phono pre I want to try so I let him have it back. But its definitely a consideration.
Reactions: XV-1
groovemaster
110
234
283
What excites me, in addition to the features you described, is this RECOMPIZER function to expand the dynamics of records. Often I can hardly believe what is still hidden undiscovered in the groove.
groovemaster
groovemaster
110
234
283
Loading options:
Eric, Update!
Which is certainly good news for the many transformer fans. The new MM/SUT phono board especially for transformer operation at the Phonolab has just been released.
It has 7 different input impedances. 100K ( for the Grado fans surely pleasing!), 47K / 32K / 24K / 20K / 16K / 14 KOhm.
Means in practice: With a transformer with 1:20 amplification I achieve in the setting 14K an impedance of 35 ohms, which the pickup sees.
An Ortofon SPU for example is terminated with 35 ohms and not with 250 ohms, which would result with 47K MM standard value at the 1:20 transformer.
That low impedance systems can develop much better at 35 ohms than at 250 ohms probably does not need to be explained.
Here the Phonolab PRO right at the Kuzma Stabi, which harmonizes very well.
Reactions: tom539 and shakti
XV-1
3,616
2,625
1,860
Sydney
Eric, Update!
Why have Audiolabs released a SUT?
What is wrong with their active gain stage for MC and MC loading?
or maybe the question should be, what does the SUT do that the active MC gain cannot do?
groovemaster
110
234
283
@ XV-1
The use of transmitters is not a question of wrong or right. Here, personal taste comes into play as an option that can sometimes be very appealing. I have experienced several situations where the MC direct input was clearly the better solution.
But that's the beauty of vinyl playback. The design scope is as large as the tastes are different.
I see you use SPU Cartridges. Many SPU users I know like to combine them with SUTs. Hashimoto, Consolidated Audio, Ortofon, Phasemation, Silvercore and so on.
Reactions: XV-1
Solypsa
1,811
1,400
275
Seattle
www.solypsa.com
@groovemaster Thanks for the update; indeed I have already been made aware lately.
@XV-1 AS always offered an MM input option but as you can see the loading choice was more about changing capacitance for...mm carts. Makes sense they offer an MM option tailored to SUT use with more range in load and not added capacitance- after all some buyers may already have a SUT collection or opinions on whats best for a given cart. In any case AS has not released a SUT...just the input option to use one with greater adjustment range...
My demo is MC on both inputs and it sounds great, but will be getting a sut input card to try for sure. In my home made tube lcr phono I use Silvercore SUT ( which I have been happy with ) but of course in this case its required to get the gain ;)
Reactions: XV-1
groovemaster
110
234
283
In the meantime, more and more vinyl lovers are acquiring a taste for transformers and matching phono stages. Our german AS community member combines his Phasemation transformer T-550 with the AS Phonolab PRO from Audiospecials in the 16KOhm setting at the MM input. The Ortofon SPU Classic GME comes more alive with this low Impedance he reports. I asked him, what amping do you use?
Devialet, it works great. This chrome beauty I like for its look, too. Recordplayer is the Bauer DPS-3.
so, keep swinging!
groovemaster
Reactions: tom539
groovemaster
110
234
283
The Kenwood KD 750 is certainly still known to many as a top recordplayer of the late seventies.
I asked its owner, why just the KD750 with the AS Phonolab?
"As a pianist, I simply have a strong association with my Steinway grand piano whose deep, black, noble high gloss reflects the grandeur of my classical music. The Kenwood conveys this to me, as does the AS Phonolab phono amplifier from Audiospecials.de . Completely handmade, it shows that - Made in Germany - today again stands for a tradition that can be described as a combination of sophisticated design and outstanding technology. The AS high gloss front in deep black also reflects the spirit of classical music. On the other hand. It has two inputs for two tonearms. On the right side is my Nottingham player in the OFF.
Groovemaster
Reactions: matakana
groovemaster
110
234
283
The AS community likes to share photos of their SET Up. Here is a very successful combination of Thorens TD 124DD and the Audiospecials AS Phonolab PRO below.
Phonolab_PRO_2.jpg The outstanding signal to noise and thus also dynamics never cease to amaze. This is 100% handmade, a very exclusive product Made in Germany Cologne.
groovemaster
Reactions: mtemur
Lagonda
3,502
4,802
1,255
Denmark
View attachment 106709 The outstanding signal to noise and thus also dynamics never cease to amaze. This is 100% handmade, a very exclusive product Made in Germany Cologne.
groovemaster
Yes, and judging from prior posts, you and Solypsa are the AS community ! ;)
groovemaster
110
234
283
By the way, the AS Community also stands for Analog Spirit. Everyone is welcome, as long as they can contribute something interesting and enrich the topic of phono amplifiers for vinyl fans. Here is a nice set-up with a Technics turntable in a very elegant USM rack. The Technics is well decoupled. Not everyone can do that.
groovemaster
110
234
283
"Less is more". This is what the AS Community has in common with its Audiospecials AS Phono amplifiers. For many, this is one of the reasons to buy, so as not to get lost in the sea of buttons.
The front is puristically tidy. Only the two rotary knobs of the RECOMPIZER for dynamic optimisation are visible. The two LEDs indicate which input is active. Left LED bright means input 1. Right LED bright means input 2 is active.
The back side has everything the heart desires.
Here is a set-up with the integrated amplifier AIRTIGHT AT-201H. A perfect match. Sounds tuby and precise. In between is a passive Dodocus switch with motor potentiometer and remote control. The unanimous opinion was that nothing more was needed.
Our playlist, Lilly among clouds, the green cover below, Mothers Finest, fasten Seatbelts and so on. AVA MAX Million Dollar Baby for the chart lovers.
groovemaster
RaceDoc
34
27
125
Germany
Audiospecials Phonolab and surroundings...
