What exactly do you need to tell your carpenter to build you the most amazing listening room? I am interested in all the details of what makes a perfect room.
And what is the smallest room size to accommodate a full range speaker?
Thanks
Thanks
Thanks
What speakers are you using?
That's a tall order for a carpenter
No offense, but your question is like 'what do I have to tell that cute girl over there in order for her to come home with me?' Ask 10 people get 10 different conflicting answers. Ask a 'Pick Up Artist' (yes there are people who do that professionally and are damn good at it judging by their conversion rate) and maybe you'll be in business.
You need:
- a good size room with favorable dimensions (see the white paper I wrote for a start, there is more in Toole's book, even though he discounts room dimensions because he uses multiple subs)
- proper noise design and construction. Noise doesn't get in, noise doesn't get out.
- acoustic treatment designed in relation to the radiation pattern of the loudspeakers (different for cone/dome conventional forward firing, dipoles, constant directivity, etc)
- appropriate electrical design to supply proper low noise, low stray ground current + low impedances
- appropriate HVAC design to maintain air temps yet meet noise criterion
Build out the shell, then do an initial round of acoustical measurements to validate your design, then do the fit out, then finally do the calibration.
Thanks
Thanks, Nyal. I ultimately need a project plan. Any chance you could "peel the onion" a bit, and provide some more detail on any of the items above? If this thread works, it could be a great resource for all audiophiles in the world and help the WBF further distinguish itself.
I've posted my thoughts on Richard Rives elsewhere on this forum. In fact, you commented on it.
Sorry... getting old and can't remember crap anymore!
CRC! I have the exact same disease. However I have decided to blame the problem not on bad memory but that at my age, all of the memory storage is occupied so when I learn something new, I need to forget something I used to know.
Hence the term: "selective negligence"![]()
(see http://www.whatsbestforum.com/showt...-acoustician/page2&highlight=room+acoustician)
If you do a Level 3 Project and Richard's Business Partner is involved (Chris Huston) then I would actively consider his firm. If not, I would strongly urge going elsewhere.
Rives Level I doesn't include measurements. Level II and III do, at least from their website.
Richard sent me his measurement system. I did the measurements and sent them to him and his response was the same: "it's not the room" when it was obvious to anyone who heard the room (including some of his competitors) that it was in fact, the room. Since every other variable had been dealt with, the room was the only possibility.
Either (a) his measurement system is inadequate or (b) he doesn't know how to use it or (c) he didn't want to be bothered or (d) whatever the issue is in my room traditional measurements will not show it. (As an aside, Dennis Erskine and his partner came and measured my room and while it was clear the problem was the room, their measurements apparently did not tell them what the problem was)
Richard was in Atlanta twice during this time period (CEDIA shows) and refused to come by and listen!!
It would be interesting to get Rives' side of this story.
