check the Analogmagik and Adjust + threads???? Perhaps an actual pointer will help..
I don't recall seeing Zenith in AM? Is this the newer version??I’m using Analogmagik program to correctly align zenith too.
Dear J.R.Hi @airbearing. When changing the size of the contact surface of the stylus by means of altering its azimuth angle, all you are doing is changing the surface area (MAYBE) but applying the same force to that new area. In other words, a one inch cube that has a mass of 1 gram applies the SAME force against its resting surface as a half-inch cube that also weighs 1 gram. The change in size of the object does not change the APPLIED force. It only changes the force over a fixed surface area. Since applied force did not change, skating force will not change.
Further, coefficient of friction is independent of surface area except when the surface area gets too small and begins digging into the material. One could argue that vinyl deflection is greater with smaller surface area but I am not aware of any studies that have shown that this effect is great enough under NORMAL PLAYBACK CONDITIONS to affect skating force.
no, but you can use vta track to adjust zenith. it's a confirmed method by owner and creator of program.I don't recall seeing Zenith in AM? Is this the newer version??
The VTA track is going to be very sensitive to zenith alignment. If zenith is misaligned, you'll probably see VTA distortion measurements higher than 3%. It's easy to measure higher than 10%, even. My Opus 1 measured less than 2% left and right on the VTA track after I iterated on zenith. Don't forget to recheck overhang, though.I don't recall seeing Zenith in AM? Is this the newer version??
Hi @airbearing. Perhaps we'll have to agree to disagree. I am not saying that there aren't other factors that influence anti-skating (as seems to be your point). I am only saying that those factors are so infinitesimal compared to the greater "compromise of averages" that we have to use when applying anti-skating in the first place that it doesn't provide benefit to account for those factors. There is a point where the improvements in our formulas begin to approach the "noise floor" that any randomized, normal distribution of standard variables would exhibit.Dear J.R.
you need to take into account the breakdown torque and the statical pressure on the groove edge.
support pressure is a dynamical pressure.
best
E.
www.AudioCirc.com
I’m happy to put it to the definitive test. I will add stylus azimuth angle as a factor in our coefficient of friction tests that we plan to run before the year is out. We will measure the results on various stylus profiles with plus/minus 1.5 or 2 degrees of change. If it is a less than negligible phenomenon it will be captured in the results. Sound good?Ha ha J.R., you are playing down a little the impacts of all these factors. They are definitely here (!).
In my eyes it is somehow funny that we have listened to music in the past 60 years quite well only to hear now that we forgot to control and correct the Zenith.
Anyway I wish you the best in your activities.
E.
www.AudioCirc.com
Lastly, the community had gotten so used to living with the pinch effect that is so characteristic of conical and elliptical profiles that they may have not noticed they now had a way to avoid it altogether with fine line contact styli.
AHA!!! Dave, that is an excellent question.I think this is an interesting concept when you get to mono where conicals seem to "rule the roost". My problem with the "pinch effect" in a purely lateral cut record is what happens to the vertical component generated particularly with a cartridge like the Fairchild 225 that does not have vertical compliance?
dave
Yes. Another possibility: perhaps they use less rigid cantilevers and/or have a bit of low compliance vertical excursion allowable???from the simple perspective I see two possible options. ... the stylus is either going to momentarily mistrack or excessively wear the groove at the pinch point. Neither can be a good thing.
dave
Ortofon SPU Mono CG cartridges also have a flat cantilever design, presumably to give a touch of vertical complianceThe Pierre Clement cart in your link has a cantilever design similar to the Fairchild 225. It has a flat horizontal cross section that gives immense strength in the lateral plane where needed and a fair amount of flex in the vertical plane. I see this flex as a bit of vertical compliance that may substantially help deal with the vertical content caused by the pinch effect. As an aside about using "cantilever flex" as part of the suspension this is exactly what the Neumann DST does. The flex of the cantilever which is rigidly anchored to the body is what determines the compliance of the cartridge.
dave
I don't think the question is whether the ear is better than measurement tools. Rather, you can't do anything about an imprecise zenith alignment unless you know you have one. Do you know if you do or do not?The need to fine tune azimuth and zenith ( and quite frankly dial in vtf and vta ) are all for the same reasons - deviations from ideals in manufacturing. I don't see this as news.
What is up for debate is whether our ear is sufficient, or even better, versus measurement tools to find the adjustments.
Also we should expect high dollar carts to have grading applied to cantilever assemblies. As well as the rest of the parts. Despite this perfection will not he achieved![]()
