"Do you expect the Mark Levinsons internal DAC is on par with the streamer/servers?"@Ratbastrd
Looking at the chain, do you expect the Mark Levinsons internal DAC is on par with the streamer/servers? (I just don’t know)
It would be a pity if any connected digital source couldn't really shine. In case a higher level DAC is preferred (again, if) you could perhaps have a look at a servers with DAC, or good matching server/DAC combinations. A good listen at home will show synergies with your set/room.
Furthermore on the servers, you could add the Innous Statement to the list. At AudiophileStyle forum you’ll find a MU1 topic that could be interesting for you.
I'm sure that I could upgrade, and potentially find a better solution, but its also possible I F' it up, or create other problems, and thus not worth the added expense. I'm in the 90th% for that element.
PS: I know the guy's and the back story to that program. They are some of the best in industry, had an enormous budget, with access to pretty much anything they needed. Within Harmon, the ML 585.5 is considered a crowing achievement.
