What’s the source Ked, it’s very flat sounding lacking any harmonics and overtones. It’s the same in both videos.
david
I’m not familiar with any of these components Bill just assuming the fault lies with the front end but I could be wrong. There’s also the hollow tunnel effect of speakers to get past in these videos.Kedar will have to confirm but pretty sure it is the Sikora Reference Turntable.
david
Listen to the hollowness and slight echo around the violin and specially the piano in the 2nd video, you can easily hear that they’re forced through a pipe or a vent with eyes closed.What do you mean by hollow tunnel effect, David?
david
You and Peter were supposed to convert Al looks like he converted youwith eyes closed.
david
david
Let’s get serious here Ked those speakers are a plastic pipe with a driver stuck at one end, what setupThese particular videos don't sound that good on it I actually posted it to contrast the strength of the dual woofer FLH of the Altec on the same track.
This is an older version of pnoe smaller slightly than the general's but the speaker was always very sensitive to set up. It usually show cases problems till it is spot on
Let’s get serious here Ked those speakers are a plastic pipe with a driver stuck at one end, what setup?
david
Well, these aren’t WEs nor have anything managed that I hear. Simplicity is great when it’s real engineers involved you’re literally listening to a plastic pipe with a driver and it sounds like it too.That's one way of looking at it, the simplicity of the best driver in a one way, so no crossover is another. Backloaded horns have challenges timing the bass from one mouth to the upper frequency of the other mouth that needs to be managed
Well, these aren’t WEs nor have anything managed that I hear. Simplicity is great when it’s real engineers involved you’re literally listening at a plastic pipe with a driver and it sounds like it too.
david
Managed by adjusting speaker position?
