FYI That's not the ddk CC cord......and do u really think u can hear 19.0 vs 23.4? I think not.....As it turns out, the Pass XP-25 comes with a Ching Cheng, which I dug up and measured. As expected, it is slightly more noisy, picking up radiant EMI along its length, and we know this is not a shielded cord, which also means it radiates hum (also measured separately with a simple electrical device). Part of it may be the alligator wire as well. You would not expect this stuff to be anything worth more than what they sell for; this is a typical run-of-the-mill cord, and what I call high-end audio junk
Ching Cheng
Baseline Wall Outlet
Ching Cheng
Yup, and I said none of that. Personally I care more about the fact the cords are not shielded and radiate hum than the noise they pick up; plus the quality of the copper and overall construction. These are what we call stock cords.FYI That's not the ddk CC cord......and do u really think u can hear 19.0 vs 23.4? I think not.....
Precisely, and we know whyI am not sure if anyone is calling CC power cords 'high end'.
Therein lies the rub. We think it is those QR/BB devices in there that render that effect.
Our analog power supplies are drawing current in pulses, at around the peaks (positive and negative) of the waveforms. He is probably excluding digital power supplies."Note should be made that the inventive circuit operates only in a power system where current is drawn in pulses. It has no advantageous effect in a system where current draw is linear across the entire AC waveform."
So, good for Power Amplifiers perhaps, but not so useful for frontends?
Who's we?Yup, and I said none of that. Personally I care more about the fact the cords are not shielded and radiate hum than the noise they pick up; plus the quality of the copper and overall construction. These are what we call stock cords.
This is basic common analog power supply knowledge. This is also partly why there are associated capacitor banks. And I am referring to any component that would be using such analog power suppliesWhich component's analog power supply specifically do you mean? And how do you know this to be true if you don't mind my asking? (Other than it being mentioned on Shunyata’s write-ups).
Good point - let me repeatThe filter might be functional outside the range of the meter. Also there should be an actual load connected to the output (the meter is rather a high impedance)
Yes, but not needed, here are the values of the filter from another manufacturer (and there are a few more with the same exact execution)Would you also have a multimeter with a R, C and/or L measurement option?
There are no capacitors or coils in the Shunyata, but I will see what I can do. Meantime, using a 12V electronic transformer as load to the EMI-reducing device confirms that, YES there is a drop in noise, and the more current I draw (by turning up the lights) the lower the noise floor, but not very significant either: 348.1 mVp-p down to 332.8. I am going to edit my previous post and strikethrough what I said and correct it.Was more thinking of RCL measurements on the Shunyata ;-)
I don’t think anyone said the whole component draws current in pulses. We said the analog power supply of the component does, and then Shunyata claim they can improve the instantaneous current delivery as discussed in the patent, because their products interact with said power supplies. Any arguing should be done with them not anyone else. However, measurements posted do show such behavior. If you think otherwise, or that the measuring device does not represent a real analog power supply, so be it.However, I don’t believe that necessarily equates to the component as a whole drawing current from the mains in pulses.
