@PeterA was the choice of Sipo for the stain matching / asthetic or also for vibration qualities?
excellent question. Initially it was only for aesthetics it was the recommendation from the cabinet maker after seeing the other furniture in the room and the price of genuine mahogany.
Sipo is about the same price as walnut maple cherry. Given the dimensions, prices go way up for mahogany. Sipo is related to mahogany and almost indistinguishable quartersawn and stained. It is much heavier, denser, and stronger than the birch plywood shelves I have on my existing rack. It is also stiffer. I suspect it will sound better than the birch plywood rack. But the rack is really they’re only as a support mechanism for the steel plates which directly affect the sonics.
The top shelf will support 420 pounds of gear and steel plates. Each of the other shelves will support 200 pounds. The rack itself will weigh over 200 pounds. My guess is the total rack plus components will be around 1100 pounds.
It will be very functional, and should fit right into the aesthetics of the room. There is also a lot of design behind it based on my past experiments that will benefit the sonics.
