What sort of age are your Duos? The latest XDs are even more solidly fixed together with solid aluminium spacers to attach the upright poles to the bass enclosure, compared with rubber bobbins on earlier models. The mid-horn is also more solidly fixed to the uprights (and hence the bass enclosure) and I'm unconvinced this is better than good vibration isolation.The frame on my Duo's vibrates quite a bit when listening to loud music. I've tried tightening all the bolts.
I've recently put anti-vibration material inside the canisters (the black sticky rubber stuff you get for car panels) - this did reduce the frame vibration a little.
I'm now thinking about replacing the hard white washer that's placed between the mounting bolt and the frame. Maybe replacing that with silicone or sorbothane would reduce the transmission of vibration from the canisters to the frame?
I think maybe there ought to be another soft washer on the other side of the bolt as well for maximum dampening?
I'd be interested in your thoughts.
--Jatinder
Hi BigDog,
I'd be interested in seeing some pictures of the older AG frame mods...
Hi Jatinder. Could you open the link in my posting from Thursday - post no 203? If not, I'll post the photos here.--Jatinder
Hi Blue58Vibrations will still travel via the bolt no matter what spacer/washer is used so how about looking at alternative options such as Teflon or PEEK bolts and a Teflon spacer.
When building the new frame, did you put in any thought into time aligning the horns? I found significant improvement to my Unos when I pulled the midrange out 12” in front of the tweeter.Hi Blue58
Not necessarily. With my mods to my early Duos substituting an F Frame with the original 3 upright tubes, the tubes are bolted to the frame but there's no metal-to-metal contact. The holes for the bolts are over-sized with a neoprene tube separating the bolt from the frame, there's a pad of Sorbothane between the frame and the horn tube and finally there's a neoprene washer under the head of the bolt. You can see some of this in this photo. No hard contact.
Note also that the F Frame is also isolated from the sub enclosure by re-using the rubber bobbins that AG used to fix the uprights to the sub. They may look solid but give them a squeeze. There's no solid contact between the sub and the uprights in original AG design and the same applies to my F Frame. Why AG has now moved to solid metel-to-metal connections with the Duo XD I'm not sure, I'll be modifying my XDs soon. Peter
No. I chose to keep the drivers in the same allignment as orginally set by AG. I also chose the height as equivalent to the middle set of fixing holes as this suited my seating position.When building the new frame, did you put in any thought into time aligning the horns? I found significant improvement to my Unos when I pulled the midrange out 12” in front of the tweeter.
RJ - thanks.Good stuff Peter, definitely looks like a viable solution and worthwhile the effort. Perhaps Jas could adopt the same approach...
Hence, it was very hard for me to justify the extra spend and so I moved it from my short list and ended up with the CLX's.
Cheers to AG horns!
RJ
Huh? In my setup, the bricks are not visible from the listening seat. The bricks are only visible when you are up close and look for them. I'd post a picture but I don't have a working camera at the moment.I've seen and heard the effects of these weights and they do work, although in many setups I've found them awful to look at...
This is very interesting to hear - Hear hearRJ - thanks.
A couple of years ago when I had 2002 Unos in my system, I thought it was time for a change and I was looking at electrostatics after hearing a friend's Quad 2905s. I went for ML 13As but sadly I hadn't arranged a home demo first - only a showroom audition and rave reviews. Unfortunately in my room where speakers are 12-15 ft from the back wall, the old Unos sounded better by a significant margin. This was by unanimous agreement with several friends including the Quad owner. MLs don't like open space - presumably because half their sound energy is projected backwatds and this needs to be salvaged.
By lucky chance I found the 2006 Duos at a good price and bought them. I'm hoping the new XDs will eventually out-perform these older Duos, but they are putting up a very good fight.
Firstly, and with apologies to owners, I think the Trio is not your best move, even if you have the room to accommodate them. It's the only one of the 3 original AG designs that has remained much as it was in the 1990s. The latest Duo and Uno ranges are hardly recognisable from the early days. Note - this is my personal view with no scientific support! I've only listened to Trios once and that was when I had Unos in my own system. I wasn't tempted to upgrade that far even if funds allowed!This is very interesting to hear - Hear hear.... I have been wanting and hoping to replace my older Duo's with newer Trio's (preferred) or Duo Mezzo for some time - just looking for the right deal on a used pair. From what I think I'm hearing you say, you don't find the gap from old to new Duo's that large. I wonder if you would mind elaborating a bit more?
