Thanks leftyYes. EL38 adapter also works with GEC E3375 - looks like a GEC KT77 with top cap - but much cheaper than a KT77.
No more adapters for me.
How does the GEC KT77 compare with the GEC KT66 in your TRP?
A no-go for me too. There are so many other tubes that don't require an adapter. Besides, when you find a really good-sounding one, you don't feel the urge to get out and hunt for another type.Even worse and therefore out for me
But thanks for the much appreciated info![]()
Which ones are your favorites, then?A no-go for me too. There are so many other tubes that don't require an adapter. Besides, when you find a really good-sounding one, you don't feel the urge to get out and hunt for another type.
Reissue TUNG-SOL EL34B paired with BRIMAR 5z4G. They provide a beautiful detailed full-bodied sound with wide and deep soundstage in my R2R TRP. I haven't even tried NOS output tubes yet. My recti tubes are all NOS though. Right now I am burning in one RCA 5U4G. I find that it lends a more forward feel to the resulting sound than the BRIMAR. More details as well. The BRIMAR is definitely warmer.Which ones are your favorites, then?
It does seem like an unnecessary difficulty, but what if there is a tube you really love and you cannot wait to give it a try?A no-go for me too. There are so many other tubes that don't require an adapter. Besides, when you find a really good-sounding one, you don't feel the urge to get out and hunt for another type.
I'm going to directly compare GEC KT77 to GEC KT66 black base to Mullard EL34 metal base this weekend. I really like a forward vocal sound, and I think this comes from pronounced mids. These three tubes seem to do these things very well. Overall, I'm preferring these tubes and others I've mentioned over most 6L6 in this DAC.Thanks lefty
If several people with ears I trust say you need to try tube XY from the manufacturer YZ because it is so excellent, I might give it a try even if that tube needs an adapter but buying tubes and adapters on a hunch, that won't happen for meIt does seem like an unnecessary difficulty, but what if there is a tube you really love and you cannot wait to give it a try?
Have a fun weekend and I'm looking forward to your findingsI'm going to directly compare GEC KT77 to GEC KT66 black base to Mullard EL34 metal base this weekend. I really like a forward vocal sound, and I think this comes from pronounced mids. These three tubes seem to do these things very well. Overall, I'm preferring these tubes and others I've mentioned over most 6L6 in this DAC.
Look at this on eBayAny link to EL12 adapters?
Those are the ones I have. Also works with EL11. Really enjoying these tubes in the DAC. Big bold sound with hint of warmth from Philips and RFT. A little more airy and brighter from Telefunken.Would you recommend them?
I should also be getting the Supratek next month. Anything wrong with the umbilical or perhaps just getting something longer?On a different topic, getting a new umbilical for my preamp has allowed time alone with the TRP. Since getting it back from Taras after repair in January, I hadn’t taken the time to run it directly to my ATC actives from the dac’s faux XLR outs. I’m using EL51s and have rotated rectis, but mainly the 596. At low to low medium volume the sound is very clear and relaxed and modestly warm, although a bit laid back from speaker level. But as the volume goes up more, the dac feels overdriven, thickening, straining a bit. It reminds me of PS Audio’s Paul McGowan’s video comment the other day about their original preamps, which were a pot and port: very clean but not particularly robust, and lacking much bass (he says the primary reason good preamps are so expensive is to get bass). A good preamp really does make a difference.
Mullard metal base GZ34. The bases and shapes of all the tubes have to match right?What rectifier are you pairing with the Mullard EL34 metal base tubes?
Mids magic in the EL34 metal base. That's what stands out the most to me. Vocals that really grab your attention. KT66 smoked glass black bass do everything right/nothing in particular seems to stand out. "Well rounded" I think is the term. Just plug in the KT66 when you don't want to think about the tubes. The KT77 seems to be somewhere inbetween. Not huge differences between the tubes though for me. If I was looking to change the sound signature significantly, I'd look at another DAC, preamp, amp or speakers.Have a fun weekend and I'm looking forward to your findings![]()
That is by far the best strategy. Impulse buying may get you nowhere.If several people with ears I trust say you need to try tube XY from the manufacturer YZ because it is so excellent, I might give it a try even if that tube needs an adapter but buying tubes and adapters on a hunch, that won't happen for me![]()
