How much air flows thru an open window? Especially a wide open one?
Sound is energy and energy disturbs the air the way a rabbit leaves foot prints in the snow.
This is on the recording, and I am only now beginning to hear it fill my room.
"There's something in the air besides the atmosphere."
- Lena Lovich, Lucky Number
A fascinating topic and two fascinating sentences. Don't know if I agree with the first one, but I like it. None of what I'll write here is meant as a criticism.
Been some talk about 'air' lately. Peter, I'm interested in exploring your experience more, in light of my own, so that I can understand better what you're saying and perhaps refine my own vocabulary. You write with well constructed sentences. What is interesting is your indicating you are 'only now' beginning to hear it' fill your room. So the referent of 'it' is ... what? Air, sound or energy. I'll speculate that referent is 'air'. Is that right? Kindly bare with my analytics.
I read you as saying the experience of air is new for you. This is the part that is puzzling within my own experience. I've never thought of 'air' as something unusual to hear or experience from my own or other audio systems. I agree that it may take a certain level of system to sense it or experience, but nothing particularly fancy; I'm guessing the majority of systems here on WBF are capable of revealing it from a recording that has it. So I ask myself is Peter talking about the same notion of air that I have, or is this something either new for me or that I call by a different name?
Air is the media on which sound energy travels. (No air no sound.) It's in the hall. I think of it in terms of being part of the venue context. The air is defined by what contains it, the inside of the building that holds it. That containment influences the sound energy in a particular way that (partly?) differentiates from sound energy outside, concert in the park, etc. I hear the interaction of sound energy with its context, it reflects off the hall's walls, ceiling, floor, etc. Curtains, baffles, carpeting, etc. influence that to a degree that each venue, each hall, has a fairly unique sound/influence of its own. But virtually all venues yield some sense of air. Well, maybe not an anechoic chamber so much; there the air is typically dead.
I also hear some sound from an orchestra that is less influenced by its containing venue, moreso from the interior of the orchestra, furthest from the walls. But there is still plenty of air there. I hear sound energy rising up, into the air as it were. I usually describe that as a transient cloud above or harmonics hovering over the performers. Sometimes I have a sense of the air separating performers or sections and what happens in that space when either, say, one or both play. Quartetts, Trios are an example too.
There's the sound of air in a venue further enclosed by an instrument. The tube of a flute or clarinet, the wood body of a cello. Hearing that is what I sometimes describe as a "lit from within" quality, or as Nora Jones describes, "the dark and shady corners of a violin", the woodiness of an instrument.
I suspect to a degree, that how we hear 'air' is tied to timing. Reflection off a back wall, etc.
Yes, it's on the recording. (The 'mixing' of the performance's sound energy with the air in one's audio room impacts the way wed hear the recording, but let's leave that for another time.)
The capacity to reveal air from a recording is I believe a product of the recording and the source. One's analog front end is critical and obviously some gear is more revelatory of what's on the recording than other gear. There is some gear that is known for it's ability to render air and spaciousness; whether that is homogenizing or revealing is another topic. Holt doesn't discuss "air" but he defines "airy": Pertaining to treble which sounds light, delicate, open ... Apparent airiness can be exaggerated by a rising HF response or excessive L-R content at high frequencies - both typical of many moving coil cartridges." Well perhaps ... low frequency instruments can 'have air' too.
So, Peter and @Al M. , is any of what I've described similar to what you're talking about hearing?
On Tuesday I had the pleasure to hear Peter's system again... and perhaps Peter can describe the most recent changes.
I can understand the energy concept from the edge of the pit but have a hard time with it as u would sit out in the hall during a performance. That local energy would certainly be greatly diminished the further away u would be from the instrument and with hundreds of bodies in the hall...
Sure, Al. I read your report and Peter's comments. I was not questioning the experience either had, but wanted to learn if I understood both of you by describing my notions of 'air' then hearing your feedback on whether I was using 'air' in a way that was similar, or that each of you could relate to. Seeing if we were on the same page or if there was something I didn't 'get' about the description you gave. I guess I was thrown off by Peter's comment which I interepreted as hearing something new, that he only now was beginning to hear. So, I asked. Sometimes it's worth (to me anyway) learning if we are communicating or at least if I am understanding what others say.
Are you listening to white rabbit smoking carricula
Ked, I am climbing out of the rabbit hole and am now on the meadow. The journey has been a long and strange trip, but I now see my path.
Time to start debating "If a tree falls in a forest and no one is around to hear it, does it make a sound?"
You are not, but save the post for 5 years later. You will really have to step out and listen to totally different systems you have no exposure to today to get that
I hear you, but I am not referring to gear. I am referring to an approach and an understanding of what is happening in the room when I record is being played.
Perhaps not being tied to gear is liberating, but without it one can’t enjoy his music collection.
Don’t you mean to ask if there’s any energy released?
Language is an interesting thing. It is usually used to convey meaning. I often struggle.
No Peter, I was addressing the key sentence for subjectivists - the one who separates physics from perception, in order to clarify things and allow some talk. We should refer differently to the air wave (the physical entity) and perception of it (the sound).
The approach comes from listening. It is listening to totally different systems than you have exposure to. Changing speaker positions, toe in and cablea will never change the Magico pass sound. If you like that, great
