Sure, Peter. I'm no expert by any means but I'll share what I think I gained since purchasing a Shure MV88 stereo condenser mic that connects directly to my iPhone XR. But I've learned enough to realize capturing in-room recordings requires a strategy, process, mindset, etc just as with high-end audio. IOW, it requires some thought. Otherwise, the video could be embarassing if sombody were just flying by the seat of their pants.
Below are some things I think I've practiced, learned, and/or observed along the way:
- Assemble and tune the most musical playback system I could muster. Duh?
- Practice makes perfect. I had to ramp up with some practice runs and then playbacks via iphone, youtube, etc, to develop a familiarlity how things will be translated. Once confortable, then it becomes more of a rinse and repeat process i.e. no further config changes and just push record.
- As some already mentioned, likewise my smartphone/mic config can be a bit selective about tracks it captures fairly well. Perhaps others' configs are equally selective. It's not a big thing but every so often there is a music piece that just will not record well. Or is incapable of sufficiently delivering whatever I'm hoping to share.
- My goal is to be an absolute minimalist about anything related to high-end audio so I try to keep this same mindset with recordings - keeps life simple that way. If you're a minimalist keep the recording configs to an absolute minimum also.
- At my stereo mic app settings I have it configured to accept / capture the widest stereo range possible to ensure wherever there is music in the room the stereo mic stands the best chance to capture it.
- You can only squeeze so much blood from a turnip and likewise with a little stereo condenser mic but it still seems to do an overall excellent job for its size.
- I've learned that in my case anyway my recordings capture a very small percentage of the overall gestalt of the in-room presentation and also some dynamics will suffer most. As such, I need the in-room volumes to average around 100-102db or higher depending on genre, etc. I don't know how this can be measured but I'd venture the gestalt captured is in the 1/20th to maybe 1/50th range of the in-room gestalt. The 100 - 102db in-room volume range is fine for me because it's only about 3 or 4 db higher than my average listening volume levels. For others maybe some little ear plugs are in order. Some playback systems may not fair so well at these volumes. If that's the case, I'm guessing turn down the playback presentation volume and turn up the mic's gain accordingly.
- The Shure MV88 mic also provides a nice video app instead of the stock Apple Photo app. I was using this Shure movie app for some time but then realized that movie app was causing the recording mic to overload at lower volumes. Or I just had things poorly configed. Anyway, I'm much more satisfied using Apple's stock photo app with Shure mic app running in the background. My recordings seem more robust and accurate with this config and less potential for overloading the mic. So mixing'n matching apps seems to benefit.
- Should be no surprise but most deep bass is also difficult to sufficiently capture. At the Shure MV88 mic iPhone app to manger the microphone input signal, I've got all configs either neutral or flat. Except for bass. Hear I do boost the EQ for the bass regions to capture more bass. And IMO works suprisingly well. Sure some may call it cheating, but IMO I'm simply doing my reasonable best to relay the most accurate message possible about the in-room experience. No matter though, cuz it all still falls way short.
- My mic gain in the iPhone app ranges from 22.5db to 27db depending the music. 99% of the time this remains the same at 22.5 but every once in a blue moon there is a piece or two that benefits from the 27db gain.
- iPhone's on a tripod placed about 3 feet in front of my ears and about 8 ft in front of the components and speakers.
- Get some cool little lights or do something for some eye candy.
- Evaluating my own videos after recording is also a nice way to boost my listening skills a notch or two. I know what the piece sounds like in-room and then I'm evaluating and comparing what's lacking and what's retained to the in-room presentation. Nothing better than critical listening to environments and music we're most intimately familiar with.
- Never forget the recording of an in-room playback presentation is a counterfeit of a counterfeit of a counterfeit with the recording medium being the first counterfeit. With that in mind, that should help generate more reasonable expectations.
- An in-room recording can't really demonstrate a truly superior playback presentation head'n shoulders over others but it could easily show that a playback system is as musical as some and/or that it may not be lacking much. If that makes sense. Though I'm sure with professional recording gear, results could be much different.
Oh, yeah. When listening / evaluating with earbuds or headphones, imagine you're a little bug sitting on your pituitary gland and watch how everything opens wide up.
One more thing. It seems to me that Youtube in particular has some kind of noise reduction system engaged during public playback. When in the private Youtube video editing section, the same piece seems to be at least around 20% more musical, higher volume, and more alive than during public play. That's a shame but it's not the end of the world. So if you listen to a video posted on Vemeo or perhaps elsewhere and it's fairly musical, chances are good it will sound less musical stored on Youtube.
At this point I'm potentially sharing more than I know so I'll stop here. Hope this helps.
