This goes against everything I've ever experienced, but here it is.
Does it make any sense to you?
Alsyvox
https://alsyvox.com/our-technology/
Anything is possible in theory, but then you have to prove it with experiments, right?
Alsyvox
CONVENTIONAL LOUDSPEAKER ON SPIKES
No matter how rigid a box is it will vibrate at some frequency.
Stiff connection to the floor gives reflected waves in the frame.
DIPOLE LINE SOURCE ON SOFT LEVELERS
A distribution of small forces is less prone to excite frame vibrations.
Compliant (soft) connection to the floor does not give reflected waves in the frame.
