it will be a different sound though, facing each other as compared to front on. I am sold on dual woofer FLH
Then you "choose" what final impedance you would like for the two bass chassis and either wire them in series (two 4 ohm Chassis resulting in 8 ohms) or in parallel (two 8 ohm chassis resulting in 4 ohms)it will be a different sound though, facing each other as compared to front on. I am sold on FLH dual woofer FLH
so am I![]()
throat 20x20cmHi,
What is the cut off and geometry of those horns? You are front loading 2 x 15” woofers in there
they re open at the front......the last pic is of the rearchambers with filterbox on topLeif, you don't like them open at the front?
The one that i had in mind has bass horn coming in at 500 so not too different from 550
no it´s a 4 m long 1 fold horn designed by Rune Skramstad with a ventilated rearchamberIs the sub on the right a tapped horn?
How are you dealing with time delay from such long horns?no it´s a 4 m long 1 fold horn designed by Rune Skramstad with a ventilated rearchamber
bonus with vented rear chambers apart from more even impedance is that it basically acts a a dipol with respect to room, so all bass problems from previous BR bass towers are gone..
14msek below 75 Hz is not detectable by human ear...
Rune knows his stuff...
