Agreed! I hope to find somewhere to hear one someday here in Europe.That Jadis looks like a very interesting speaker!
There are people with the opinion that the plastic/polymer domes are better damped than an equivalent metal dome. The drivers I use have either Magnesium, Aluminum or Beryllium with a dampening coating that is sprayed on. I have compared titanium with and without and there is a difference with the dampening. You can also measure the difference in time looking at a CSD measurement. I have no first hand experience using a driver with a polymer dome. I know the M2 compression driver also uses dual polymer rings.
Rob![]()
the Jadis reminds me of something from The War of The Worlds cover![]()
yes, the Cessaro gamma II, like my system, adds a tweeter on top. In this case a TAD et703.
@Duke LeJeune
I also have found out by listening that I preferred Radians over TAD's for 2". Radian delivered as much and sounded more relaxed.
I also used beryllium radian 475 like you do but when I tried TAD 2001, they were close but TAD sounded a little better on its own. I use radian 850 for my 2", I decided go for the Radian 475be for the 1" as I thought they integrated better. The bandwidth I use the 1" is also very limited so it is not enough for the TAD to shine and make a difference. It could also be my a priori thinking leading me to believe same brands work better together.
I do not plan to change but first to try the jmlc 270 with 4003 and jmlc 1400 with 2002. If they better what I have now audibly and measurably then I will change them.
I was really blown away when I heard it. I would put it in the middle of an Avantgarde Duo Omega and a classic Tannoy 15". You get the top level resolution of the Avantgarde but the great bass of the Tannoy. The speaker bests every speaker I've heard except for the Tannoy Autograph Professionals. Full Jadis system but I don't remember the actual model of amps.
Although I love my current speakers, now that I have more room I would buy a pair in a heartbeat if they came up.
It was one the speakers I considered for the Lamm ML3. Although rare we can get them in Europe
around 20 ~30 Keuros. What is the general opinion about it? It got a very positive review in Stereophile in the 90's, https://www.stereophile.com/content/jadis-eurythmie-ii-loudspeaker the hifi press did not ignore horn speakers!
Dear Leif. You are asking a question to a guy who only pays for his soundwhere do you hipass ET-703?
For me it is everything but industrial design.I absolutely love the industrial design of those speakers!
You were thinking about buying the Jadis Horn?Audax...perhaps aerogel...I used to know the model number...I was seriously thinking about a pair then made the mistake of showing them to my wife![]()
Here is a system of a brother of my old time friend who is into vintage in Bangkok.Thank you, Francisco for pointing out to the Review.
Does anyone have first Hand experience with those very Jules Verne looking Horns?
They may be Davis Acoustics16TK drivers with different cone material and a dome added, ie. built to AG spec.Audax...perhaps aerogel...I used to know the model number...I was seriously thinking about a pair then made the mistake of showing them to my wife![]()
Was completely Jules Vernesque (if that’s a word) for me... first thing that came to my mind when they came out. The new art nouveau and steam punk design stuff of the 90’s was a bit too super postmodern. I prefer the simpler modernist functionalism of earlier horns like the Bionors.Thank you, Francisco for pointing out to the Review.
They’d look good with a pair of French Bulldogs in the room.Here is a system of a brother of my old time friend who is into vintage in Bangkok.
