Curious to see what you hear, Phil. Are there any test records with anti-skate test tracks, and what kind of test would that be...
Thanks. Regarding his point #1, this is why I called the thread "sliding force" rather than "skating force" - they are indeed different. And we now all agree that setting anti-skating by using the sliding force is not correct.
Regarding test records, I was hoping to find one that would let me measure something, not just play music.
Regarding his last point that Koetsus do not require such bias, I wouldn't know, but it's interesting that you seem to lean on at least some, to address the lean sound you are hearing.
Regarding sound "effects" of anti-skating, I would point you to the Amanda McBroom Growing Up in Hollywood, which we both liked listening to in here, years ago when you visited. With some bias, instruments on the right channel are far clearer - for example, the guitar on track 1 - and this is the first thing that jumped out on me at first. Since then, all kinds of things are so much clearer on the same right channel, when using some bias, and now with less distortion all around.
PS: Where is Myles when you really need him, to enlighten us
Yes, I am aware of VPI's position, which is reason enough to investigate further.
(...) "Arm manufacturers have tried to compensate for this force, but that is impossible because the force is constantly changing as the music and velocity change. (...)
i am finding this thread very interesting. Maybe table leveling and proper alignment setup tracking force, overhang is more critical than skating force. I tried it on my 1200G and I actually seem to like it better with no skating force so far.
Well, I just realized that the Analogue Productions Ultimate Analogue Test LP that I've been using for years does have two anti-skate test tracks:
This only means that the force can not be fully compensated, but only partially - they apply an average value. And most people will still believe that partially compensated is better than a fully acting lateral force.
IMHO basic physics clearly explains why the force exists in pivot tonearms. If people prefer to avoid using the anti- skating mechanism they must explain why or simply say they prefer the sound with it.
There is some strength in the argument that linear arms reproduce better the conditions of the cutter.
Hope to hear your test results, Tasos.
So the first track gets louder as the instructions say; not sure I am hearing distortion either way.
The second track is more interesting and the sound does drop in mono by about 10dB with anti skate and about 8dB without. I cannot get it to go completely silent. I am not sure that’s even possible when channel separation cannot be infinite ?!?!
The second test is an out-of-phase test, as the instructions say, and in mono the channels should cancel each out either entirely. A -10dB drop is great, and it shows that anti-skating works; just gotta find the best value, but without the ability to finely adjust it in this arm...
