Yep, sounded goodLooks like Odeon is showing a new model at Munich 2019.
Hard to say, I would need to hear them side by side in my room probably or at least with my AC gear to get a clear idea. I think I would keep the ones I have over the No. 33 or 38 though.That’s very interesting, Brad! Do you think you would trade up for these?
Given that this driver is producing sound well into the mids (probably up to 400hz or so) it is probably having some positive effect. Maybe it is harmonizing the sound character between bass and mid and drivers are blending better this way? It sounded very good.What the hell is the salad bowel doing on the bass driver?
It would need to be 8.25" to affect 400hz as a horn, and isn't going to provide any extra sensitivity. It's maybe half as big as it would need to be (8.25"), and according to their site with 15" bass drivers they cross more like 200-300hz area. Their models on website don't have the salad bowl.
I think it's just for (funny) looks.
Or just to look like a horn?Given that this driver is producing sound well into the mids (probably up to 400hz or so) it is probably having some positive effect. Maybe it is harmonizing the sound character between bass and mid and drivers are blending better this way? It sounded very good.
Funny.
Normally I concur mostly with Brad and Ked but this time my friends (M and D) and I found this Odeon not to Sound very good.
I have to admit though, that we didn't stay very long in that room because all 3 of us didn't like the Sound too much
We know the Odeon Sound very good as M and I own(ed) the the No. 32 and No. 38/2 and the model on demo just didn't grab us.
We even joked that they would have better hooked up the little 28/3 they had on silent display on the side![]()
Their website doesn't have this model because it is a new model. If you look at the top model on the website (no. 38/2) you will see the midrange horn is quite a bit larger than it is on this model at the show, which has about the same size midrange horn as the 28/3 model. This means that the bass on the new model will be going up higher in frequency and I think to get the blend better between the mid and the bass they added the short horn, wave guide or whatever you want to call it. This will likely enhance the output of the driver in the range they needed for the crossover, based on the overall size of the horn around the bass.It would need to be 8.25" to affect 400hz as a horn, and isn't going to provide any extra sensitivity. It's maybe half as big as it would need to be (8.25"), and according to their site with 15" bass drivers they cross more like 200-300hz area. Their models on website don't have the salad bowl.
Well, it is an analysis on my part, I did not talk directly to Axel to get the "true" explanation...guess I should have...So I was right. They have done some mods to improve coherence, which my big no no with the previous models, plus the wood like tone
Like Avantgarde likes to do as well.
They keep calling "horns" in the bass that are never ever horn loaded (not even wave guided) for the frequencies that they reproduce![]()
Interesting....So I was right. They have done some mods to improve coherence, which my big no no with the previous models, plus the wood like tone
The mid horn on the 28/3 (and the 33 and 38) look more substantial in terms of thickness and weight than the horns on the new model.Their website doesn't have this model because it is a new model. If you look at the top model on the website (no. 38/2) you will see the midrange horn is quite a bit larger than it is on this model at the show, which has about the same size midrange horn as the 28/3 model. This means that the bass on the new model will be going up higher in frequency and I think to get the blend better between the mid and the bass they added the short horn, wave guide or whatever you want to call it. This will likely enhance the output of the driver in the range they needed for the crossover, based on the overall size of the horn around the bass.
Does anyone know what electronics they were they using here?Funny.
