What is your opinion of Line Source speakers?
Reactions: thomask
Nice speakers!
I almost bought used Zeta speakers from Audiogon due to gorgeous look.
The only reason that stopped me doing is that I prefer small power SET amp.
The above mentioned QLS is SET friendly......a true 96 DB@ 6 Ohms and a nice safe impedance curve......
Reactions: thomask
QUINTESSENCE ACOUSTICS......MODEL is the QLS......39k MSRP
You can check them out here. www.quintessenceacoustics.com
Click on “PRESTIGIOUS GOLD SHOW AWARD WINNER”
Now you’re talking. I like these line source things.
JeffT, did you ever hear these speakers from your guy?
Reactions: christoph
I can recommend the line source speakers from Grandinote Italy.
http://www.grandinote.it/mach9 - en.html
During my last visit there I had the chance to listen to the Mach9, which is a real 98db line source speaker,
working well for all the SET friends in WBF :)
Will try. Their pre and power is quite good value
Will get the Grandinote Genesi Pre and Demone Monoamps soon :)
If you listen to the speakers, you should try the actual versions in alloy cabinet, I saw some old versions in wood.
Reactions: hogen
I really like Arion Apolllo speakers with 105 db/W high efficiency.
But I am not willing to give up Lansche 4.1 speaker with pristine treble out of plasma tweeter.
I do not have enough room to place two speakers side by side at my listening space on the third floor.
I asked for my wife's permission to set up second listening space at living room on the second floor.
But she is hesitant to give it go.
Thus I can not move on.
But if you are serious SET Audiophile, I recommend you to audition this excellent speaker yourself.
As beautiful as your third floor is, it is NOT suited for a Dipole Speaker.
Unless you have another room to set up a Dipole System, I would give up the thought of Dipole Speakers, because they would seriously underperform on your third floor.
Reactions: thomask
I had tried to set up WE big horn speakers on second floor if I get it.
You may be right in that I need more space.
But I used to use Apogee Signature in a space similar to my third floor.
The problem is that if two speakers are close to each other, it could be harmful to imaging of both speakers.
I have not heard the QLS speakers but I hope to one day. All of Mr Jazz's speakers are wonderful......
More in the" just goofing off" category, I just built a line source in the garage system. Eight full range Dyna ribbons per channel.IMG_4355.JPG
